We have a Glen Carradale 3207 electric heater. A simple problem which has become difficult. I need to replace both electric bulbs but having difficulty removing the front glass panel to gain access. I have done this previously a few years ago but cannot remember how I did it!
SOURCE: calypso front panel removal
Hi If you just need to get to the pump there is a access panel on the bottom.. flip it on its side and unscrew the panel you should be able to get to it... if you can't you can open the top with by pushing a putty knife in the front to push in the two clips and the top will hinge back.. then you can get to the screws to remove the front panel.. let me know how you do .. Thanks
SOURCE: Replace light bulb in a Charmglow electric fireplace
you have to remove the doors and then the lower ember cover, he lighs are underneath.... i am looking on how o make he flame move, it froze and won look like real fire anymore
SOURCE: BMW How do i change the front indicator bulb on my bmw 323i
When you open your hood there is a hole in the fender you need to stick a small and long skrewdriver in it and push the clip down and pull the light out with your other hand
SOURCE: 99 cutlass supreme headlight bulb replacement
Look at the top of the headlight assembly. There is a plastic panel on top of the assembly that is held in place by two plastic pins. Remove those pins by lifting the center of the pin and then pull out the pin. Remove the panel. Then you will find two small plastic levers that will lift about 1/2 inch. They do not come out but they will release two studs that secure the assembly. After the assembly is released, slide it forward to access the bulbs you need to replace. Installation is the reverse of these procedures.
SOURCE: How to remove door panel to gain access w/out damaging panel?
I hope this helps , easier done than said :)
1- Remove door latch bezel. (handle)
2- You will find door trim panel retaining bolt , remove it.
3- Remove the door pull handle screw cover.
4- Remove the door pull handle retaining screws.
5- Detach the interior door trim panel ( to make removal easy , release clip by lowering glass and pressing case inwords)
6- Disconnect the door trim harness electrical connector.
7- Remove the door trim.
8- Disconnect the driver door module electrical connector
9- To install , reverse removal procedures
Testimonial: "Project completed. Karaman is correct with the steps needed to remove and gain access to window. Thanks"
