FixYa.com
Tags:
Standard Televisions
Generic problem for all Standard Televisions
Metz CRT TV G3478 color problem in PAL mode
posted by Oren on Oct 07, 2007
Hi
I have this TV about 4 years, recently when I turn on the TV I see black and white picture and the colors is somtimes flickers. after the TV working on about two hours the colore return and I see great picture, it's happend for the RF and SCART (video) inputs. If I change the input signal from PAL to NTSC (change the dvd or satellite receiver definitions)I will get a nice color picture, It seems like the TV does not detecte the input signal even though it config to PAL method and only after it warm up it start to detect it.
Do you have any idea how this problem can be fix?
Thanks
Oren
Comment by Oren, posted on Oct 07, 2007
The standart I should use is PAL standart.
I live in Israel and the TV standart which being used here is PAL
Thanks
Oren
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
BingoDabbers
Rank:Wiz Wiz
Rating: 79%, 173 votes
I see from your profile that you have not specified your location which make it tricky to be sure which standard you should be using.
Comment by BingoDabbers, posted on Oct 07, 2007
Additional help will only be given if you are polite enough to give 'thanks for trying' or better.
At fixya we rely on comprehensive information to arrive at a viable conclusion.
Rating Locked! (?) Oren has rated this solution as Thanks for Trying
This Problem Also Relates To: GE 27GT271 TV GE 31GT660 TV GE 13GP243 TV GE 19GT243 19" TV GE 27GT270 TV GE 24GP653 24" TV Jensen Q2749J 27" TV
Can you Help with these Standard Televisions problems?
Mitsubishi VS-45609 TV
blue convergance
I noticed a few months ago that... Answer This...
LG 30FS4D 30" TV
lg tv problem
Message appears : temperature... Answer This...
Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Trinitron
my sony Trinitron will not turn... Answer This...
RCA F36645 TV
tv wont come on
turn power on light blinks 3... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
