Question about Fisher and Paykel Washing Machines
Washing machine not turning on at all. power point is active [verified with dryer].
No fault occurred during its last wash cycle. Next morning went to put a load on and found that it would not turn on.. So its seems the washing machine is broken! this i know.. Im just wondering if this is likely to be a repairable problem [and worth repairing i.e. cost of electronics?motherboard? something?] or not basically. Any feedback much appreciated.
    Problem Solver:
  • 8 Answers
Without seeing the machine it would be impossible to say, but if you're handy you could try to trace to see if power is getting to the timer whether it be mechanical or electronic. On some mechanical timers there are contacts which are engaged when the control knob is pulled out. Bending these very carefully can sometimes restore machine operation. I'm afraid I don't know much about electronic timers.
Posted on Nov 17, 2013
SOURCE: Wash machine will not spin
sounds like a problem with the coupling between to motor and the gearbox!
Posted on Jul 16, 2007
  • 28 Answers
SOURCE: Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Posted on Jun 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 17 Answers
SOURCE: LE fault code for LG WD-1019bd washer
Usually it is the stator at fault with an LE error. I would make sure the cable between the stators windings and hall sensor are ok back to the main control board also give the wires a good tug sometimes the copper breaks inside the wiring insulation at the white connection blocks. Check to make sure theres nothing got trapped inbetween the drum and tub this can lock the drum up and give the fault. After checking all the above i would think it would either be a faulty stator or the main control board has failed. Hope this helps.
Posted on Dec 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My washing machine , a hotpoint wdd960 , wont stop filling with water , i had problem since the frosty weather when water froze. i have took top of machine and all electrics are soaked, it is 3 years old ....
you will find at the drum bottom there is a 5mm pipe leading to the water censor remove it and blow gently into it you should hear a click and one when you release the air this means that the censor is ok but the small pipe where you took the pipe from is blocked not allowing the air pressure to build up to tell the controller that water is full enough to continue to the next cycle clean out the small pipe with a pipe cleaner, dry the parts of the machine with a hair dryer eric
Dec 26, 2017 | Washing Machines
Whirlpool duet washer power went of during a cycle
If the power is not reaching the m/c., switch off plug outlet remove the plug.
( safety measure ).
Now open the machine and check the fuse. If you trace the power cord you will reach the fuse area.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
