Question about Tunturi R60 Rower
Broken pulley wire - Tunturi R60 Rower
Mower deck wont engage
David, check to be sure that the belt is still on the pulleys and not off or broken. or a pulley has not came off. the lever that engages the blades is intact and not damaged. if it is an electric clutch, check the fuse or the wires that plug into it are connected.
Nov 05, 2016 | Garden
I have kyocera km2050.scanner u it wire has been broken.what is the solution?
its probably not broken it came off the pulley you need a tech to rewire it very difficult unless you are trained
Jan 28, 2016 | Kyocera Office Equipment & Supplies
Why Washer wont spin
Loose belt, belt broke, belt came off, transmission bad, wires are broken.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
2001 holden rodeo air conditioning broken, broken fan belt, suitable fanbelt to bypass aircon
Use the same belt as the ac compressor will not work unless you turn it on. Disconnect the wire to the ac pulley clutch and the pulley just becomes an idler and you can get the standard belt anywhere.
Dec 16, 2013 | Cars & Trucks
Hi engine runs by blades don't move thanks
Without the make and model, I can't be specific. I can only point in the general direction.
The clutch is either electric or a Spring loaded pulley.
If its a pulley, look for a broken or frayed belt.
Electric? Look for a blown fuse, bad belt or loose wires.
Hope this gets you there
Mike
Mar 14, 2011 | Garden
Kenmore 86427810 heats but will not turn. Probably belt is broken because it turns without resistence both ways. How do I get to the belt to change it?
Greetings,
if you have a filter on top there is usually two screws, remove these screws...use a putty knife to go under each corner and raise up. don't forget to unplug machine before you go this far....after top is raised. There are two screws in each inside corner of the front...remove those, disconnect any wiring on the door switch paying attention to where the wires go. Remove front and this gives you access to replace belt. the belt goes over the drum and through the belt pulley.. The belt pulley clips into a slot next to the front of the motor and lines up with the motor pulley. The belt goes thru the pulley and then around to the drive pulley on the motor... reinstall and all is well
Feb 03, 2011 | Kenmore 63942 Dryer
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
The pulley chain broke on the light on my ceiling fan and there is no slack to turn the light on or off. Can you please tell me how to fix or replace pulley?
To replace chain switch with a new one (available at a hardware store), first turn off power to the fan. Unscrew the nut on the bottom of the fan which holds the coverplate in place. Find two wires going to the switch, pull them out of the enclosure, take the wire nuts off. Now you can take the old switch out by unscrewing the locking nuts that hold it in place. Put the new switch in by reversing the instructions for removal.
Good Luck.
Jan 20, 2010 | Solar 2-wire Pull Chain Light Switch For...
Broken wire on front knock sensor
By the front crankshaft pulley
Jul 10, 2009 | 2001 Chevrolet Impala
Washer tub does't spring back...
look for the counterweight system and if pulley wheels exist then look for wire cables that have either run off the pulleys or have broken. if no pulley wheels, then system is sliding weight that may need lube
May 20, 2007 | Kenmore 24872 Top Load Washer
Tunturi R60 Rower Logo
49 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
