Question about Garden
11a 18mc056 A spring came off on the bar connecting to the carb. where does it go?
3 Suggested Answers
jj505
  • 195 Answers
SOURCE: Wont stay started
pastorcheri,
I found this site if you can not find plug behind engine/blk wire with black cover boot/ pull off.
http://www.webcrawler.com/webcrawler301/ws/results/Web/Cub%20Cadet%20Online%20Part%20Lists/1/302349/RightNav/Relevance/iq=true/zoom=off/_iceUrlFlag=7?_IceUrl=true
Please rate. Thanks. jj505
Posted on Mar 30, 2009
Knucklebstr
  • 222 Answers
SOURCE: having problems replacing pull cord
There are a million videos on Youtube, but you gotta love this guy. He does things one-handed. Every recoil is basically the same so watch this video and you'll get the idea. One note here: notice that the guy keeps his thumb TIGHTLY on the recoil while he puts the handle on (with one hand!). He never mentions this, but you may want to put a clamp or Vise-Grip (gently) to hold it or your rope will go bye bye up inside and you'll have to start over. Once you've done one, you'll be an old pro at it. Good luck.
Oh, here's the video link: http://www.youtube.com/watch?v=i3ZMVFi0yqY
James
Posted on May 27, 2011
MTD Push Mower Starts and Stops Running
Sounds like you have debris in the carb bowl,blocking the main jet and or some water still in the fuel system .did you gap the new plug at .030" ?
Oct 05, 2014 | Mtd Garden
My Briggs and Stratton 300 148 cc lawn mower surges up and down while running. Seems to run best when almost out fuel
You most likely have a partially clogged carb (main jet) and it isn't allowing enough fuel for the engine to run smoothly. This is fairly common. The carb needs to come off, get disassembled, and cleaned paying close attention to the small opening in the main jet.
May 19, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
My cub cadet 11A-18Mc056 starts right up when i push choke in it stops. I bought it at a sale almost new i think it was out side changed fule but no better
you need to take the carburetor apart and soak it some carb cleaner, the tiny passages for fuel are blocked so it gets no gas unless the choke is on.
most likely has a B&S engine, you can find numbers and letters on it, take those to a small engine repair shop, found via phone book, and buy yourself a carb rebuild kit so you will have new gaskets when you put it back together. small engine repair can get you parts for any other common mower engine as well and there are also thousands of web site vendors, do a google search.
Jun 27, 2011 | Garden
Having problems replacing pull cord on my cub cadet push mower 11a-18mc056. any diagrams would be helpful as well as a how to description
James
May 22, 2011 | Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Wont stay started
pastorcheri,
Mar 30, 2009 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
