Question about Whirlpool Refrigerators
Need circuit diagram for refridgerator model CB345W\ART850-2\G
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Kenmore refridgerator 60771
i need to locate drain opining
Oct 09, 2012 | Kenmore Refrigerators
My amana fridge keeps blowing the GFI circuit
change the GFI circuit to 20 amp
Mar 30, 2017 | Refrigerators
I need a schematic for a haier htq21jaaww refridgerator
I have a copy of HTQ21AAWW Service manual that include the following :
eatures, product code explanation and series introduction, specification, safety precaution, parts and functions, function schedule, system flow chart, circuit diagram, maintenance service and troubleshooting, troubleshooting and repairs.
If you want to download the copy, I'm online now at the pay question. Click here.
Jdvillanueva
Oct 03, 2011 | Haier HTQ21JABWW Top Freezer Refrigerator
I need circuit diagram of philips radio transistor model rd 143289-90
I need a circuit diagram for Philips Radio Model B4CA49T 1965 model can anyone suggest me where can I get it
Jan 13, 2011 | Philips Audio Players & Recorders
Refridgerator & freezer not cooling much, ice crystals on inside of freezer
Need you to unplug and remove the back panel in freezer to examine the evaporator coil. Check the defrost element and the defrost thermostat. On the back of the refrigerator is a main control board located behind a panel screwed to the refrigerator back. With the power off through all of this I need you to inspect the control board for burn marks on both sides. Click on link below and enter your model or 1 of 34 models like yours. Place model GSH25JFR in model parts search this will lead you to the many similar models like yours. On diagrams on left of your screen count eight down that shows the circuit board. If no burn marks I will tell you how to test the other parts I mentioned,
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE GSH25JFR Side by Side Refrigerator
ABOUT ONCE PER DAY THE CIRCUIT BREAKER WILL GO OFF DUE TO THE REFRIDGERATOR. WHILE TURNING OFF THE UIT IT SPARKED AT THE OUTLET.
You should turn off the power to that circuit, and replace the receptacle. The problem is most likely in the outlet
May 06, 2009 | Refrigerators
Fridge/freezer temp lights and interior light dont work
I found a repair diagram on the web that showed the parts picture and part number and saw the box in the back lower left corner of the refrigerator that housed the circuit board.
Jun 18, 2008 | Whirlpool GS6SHAXMQ Side by Side...
Don't start smooth
restarting of refridgerator may damage your compressor motor due to overload.
when you switch off the refridgerator the compressor is in load condition, sudden restart overload the motor, it consume more current so the light going to dim.
solution. If your refridgerator have no delay circuit inside,
use a refridgerator stabilizer or attach a delay circuit,
if you have the the restart delay circuit may problem repair it.
Jan 18, 2008 | Refrigerators
Refridgerator does not cool
It has a bad relay on the compressor. Looks like your model is a 50552 Kenmore. If so the part # you need is a 8201799 (start device) cost is $45.96 and you can get it at http://www3.sears.com/ or any local appliance parts house. It is # 16 on this diagram http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=10650552000&documentID=P0070128&documentTypeID=PLDM&documentClassCode=PM&titleType=UNIT&titleID=00011&
Nov 07, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
21 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
