Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
How do i set the clock om belling db3 cooker
How do I set the clock on my belling db3 cooker to get it to start working
5 Suggested Answers
  • 1462 Answers
SOURCE: belling db3 duel fuel cooker
they just pull out but need a fair bit of force
Posted on Apr 24, 2007
  • 833 Answers
SOURCE: Belling DB3 Duek Fuel Cooker
I'm not familiar with this unit exactly but I'll give you some guidelines. You have a double layer or more of glass and the glass inside the unit is your problem. Generally, cleaning glass on ovens is no problem if you use cleaners that leave no residues, don't stress the glass and don't scratch it. Prepare a flat surface covered with newspaper to clean your glass. You may use a blue glass cleaner, a scrubby or VERY fine steel wool. Never use any cleaner which leaves residue. Use lots of liquid and very little pressure. Finish with a soft cloth. Clean the inside of the door and any of the gasket you can get to. Use only a sponge and detergent unless the area is really a mess.
First, be aware that the door is spring loaded and as you remove items, it will tend to snap closed. Note that there are probably screws that are near the base of the door, probably accessed from below. Remove these first. Then, remove side screws and carefully remove the panel holding the glass. This probably comes out into the room. There is a danger that the glass is not secured inside the panel so have the door fully open when 'dropping' the outside panel. Note the positions of all clips. You may even want to take a digital picture or two. When reassembling, never overtighten anything! All parts should lay flat and insert easily. Get assistance with reassembly...you'll need another pair of hands.
Posted on Dec 03, 2007
SOURCE: Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Posted on Apr 09, 2008
SOURCE: Instruction manual for a Belling Platinum Dual Fuel DB2
main oven not working
Posted on Dec 02, 2012
Where can I buy spare parts for belling db3 dual fuel
Hi, it depends what parts your after but eBay is pretty good for parts. Element rings etc.
Jun 02, 2014 | Belling DB3 Dual Fuel (Electric and Gas)...
User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Aug 21, 2008 | Kitchen Ranges
Belling db3 oven
yes its most likely the element they are common in burning out ....because the fans still running,
Dec 17, 2007 | Ovens
Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Instruction Manuals
This seems to be a British company. Suggest you write to them at www.belling.co.uk/ They have a contact link.
Sep 04, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling db3 duel fuel cooker
Apr 24, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
