Question about Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux renaissance power hose
The hose was crimped at the canister end. I removed it; cut the hose back and (like a dummy) didn't make note of how the 2 black and 2 gray wires should be re-connected. Can anyone tell me the orientation?
  • Anonymous Mar 17, 2014
    electrolux twin clean Hi I have an Electrolux twinclean which stops comptely when you disconnect the extension nozzle from the handle and sort of cuts out. If you leave it for about 2 hours you can turn it back on. It wont go back on in less than about 2-3 hours which seems strange if its a reset switch of somekind?Today I didn't even disconnect it it just cut out when I tried to drag it a little by the hose...maybe a short in the hose is causing it to trip a safty type switch in the unit? Is there any safety switch in the unit that does this? tnx
  • Anonymous Mar 30, 2014
    There are 2 hose connections
  • 75 Answers
Call 5703261731
Posted on Jan 23, 2008
  • 102 Answers
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Posted on Oct 07, 2007
SOURCE:
Help me troubleshoot Epic 8000!
Try a different hose to test the motor. Make sure it's a good one from a working vacuum. If it works, the problem is likely in the switch, wiring, but could be the hose itself. Other problems could the the triac or relay in the vacuum.
Best thing to do is to take it in to an Aerus dealer and let them troubleshoot it if a different hose doesn't work.
Note: Do NOT use a Renaissance hose.
Jun 14, 2015 | Electrolux Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
Renny starts as soon as the unit is plugged in....leave the hose off and the unit will not start until the hose is connected
This is a problem that needs to be checked at an Aerus Electrolux store. They have the tech manuals to troubleshoot the specific problems with the Renny (Renaissance). There are three possible problems involving the electronics in either the hose handle or the canister.
When the problem was first noted, customers brought their vacuums in and the service managers simply replaced the hoses. That resulted in burning out the boards in either the new hose or the vacuum, increasing the cost of warranty repair/part replacement. Electrolux quickly sent out service updates letting the service personnel know to stop the practice immediately. I can't remember how long it took before we finally got the proper troubleshooting data, but yes, there were a lot of problems with many of the machines. Fortunately for the store I worked at, there weren't many.
Oct 16, 2013 | Electrolux Vacuums
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
How do i replace the hepa filter on a dyson dc18? I removed it and now I cannot put it back on.
It is very simple to change the filter and re-attach the canister. Once you have removed the main canister (the one that has the washable filter) you should see the plastic canister, which houses the Hepa Filter. 1) To make life easy, turn your vacuum around, so you are now looking at the back (where the hose and wand are). 2) Remove the hose and wand as you normally would, if you were going to use them. Just lay it on the floor. 3) Now that they are out of the way, you should see the grey plastic holder, towards the bottom (approx 6 inches above the red release peddle for the vacuum. It is attached to the vacuum with only 2 Phillips-Head screws, and was used to keep the hose in place. 4) Use a screwdriver to remove the screws (one one each side). Once it's removed you should easily beagle to change the Hepa Filter. NOTE: Pay attention to where the 4 inverted latches on the canister are, and pay special attention to the fact that there is an extra latch on the canister, which faces the opposite direction of the others. It is this latch on the canister, which must be located through the back handle of the vacuum, since this was the main latch that was secured by the grey hose piece, which you first removed. 5) To reassemble the canister, line up the clips,especially the one that I just mentioned, and make sure the canister is flush against the base. 6) Now, reattach the hose securing piece that you originally removed, and the Hepa Filter and plastic canister should now be fully secured. 7) Place the hose and wand back into their original position and you should now be ready to vacuum. I hope this was helpful. S.I. Educator
May 29, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
HOW TO REMOVE HOSE COMPLETELY FFROM DYSON DC17 ANIMAL FOR CLEANING
pull up extension wand. remove the wand part by pressing the gray button near the bottom of the wand.
remove canister.
if your looking at the front of the vacuum where the canister was near wher the clear bin of the canister would sit there is a gray push button. it is kind of hidden so you have to keep an eye out for it
but when you find it push it in and pull up on the hose and it will come off the vacuum.
Sep 11, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
Will not come on electrolux cannister renissance
The Renaissance and a few other models require a series of steps in troubleshooting, done in specific order, to diagnose the problem. The vacuum, hose, wands, and power nozzle need to be taken to an authorized Aerus Electrolux shop for this. The service manual is only available to the service techs, and franchise owner.
If these steps aren't followed, additional problems may result.
Things you can check include:
1. Afterfilter. This is located beneath the on-board tools. Open the access door to the tool holder by pressing latch at front of door. Squeeze clips at the front of the tray and lift to remove. If the filter is dirty, replace it. Turn vacuum on and see if it works.
2. Check for clogs in hose, wands, and power nozzle.
Disconnect hose, hold one end up, and drop a coin in. Lift end of hose so that the coin drops out. If it doesn't there's a clog that needs cleared. You may be able to do this by attaching the hose to the blower hole, placing the other end into intake and holding it there, and turning on the vacuum. If this doesn't work, it will need to be taken to the Aerus shop for clearing.
Visually check wands for a clog. A clog in the wands can be cleared with a broom stick or similar item.
Visually check the power nozzle from the bottom and the wand connection. If no clog is seen, try dropping a coin into the wand connection and seeing if it drops through. A clog here can be cleared using a wooden spoon handle or similar blunt stick.
Feb 15, 2011 | Electrolux Lux 5500 Canister Vacuum
Electrolux Lux 7000 Bagged Canister Vacuum Logo
194 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
