Question about Intel D101GGC Motherboard
E54511 205 dg41rq
I DONOT HAVE MY DRIVERS
E5200 drivers
Hello the drivers can be downloaded here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
But first select your windows system.
And heres the ram support:
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029920.htm
Your mainboard supports DDR 2 ram, up to 8 gb.
Please select a quality brand, the cheap ones does not last long.
Good luck
Jun 24, 2013 | Intel DG41RQ Motherboard CPU Bundle - ...
Hi i'm looking for my drivers.i'm using DG41RQ model.I want to reformat my computer.But, I don't where i could download the drivers of my computer
The driver's can be found at the following website.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
Apr 25, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
I need Intel Dg31Rq vedio drivers, so how can i download.
Here is the download page for the drivers for your motherboard. Choose your Operating system and download the Video drivers and chipset drivers. Good luck!
Mar 05, 2011 | Intel DG41RQ Motherboard CPU Bundle - ...
How can i get get bluetooth driver for intel dg41rqi motherboard for windows7 and windows xp
Greetings - There is no Bluetooth built into the motherboard, so I can't imagine what drivers you are referring to? Perhaps you are referring to a Bluetooth device you want to use with the board? If so you would have to get the drivers from the device manufacturer.
The full spec sheet for the board is located here:
http://www.intel.com/Assets/PDF/prodbrief/DG41RQ-prodbrief.pdf
Regards, Mikeywaf
Mar 03, 2011 | Intel DG41RQ Motherboard CPU Bundle - ...
Hi i am used window7 and my speaker is not working after install window7 please solve my problem
reinstall your sound driver, this the general problem from win 7, use mother board cd driver to install it or download driver here http://downloadcenter.intel.com/
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 21, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
How to download audio drive
To download any of your motherboard supported drivers... search online specifying your motherboard model. For example, if your motherboard model is Intel DG41RQ; search as "Drivers for Intel DG41RQ download" and you will get all the drivers that support your motherboard model from the Intel Website. From there, you can easily download your desired audio driver.
Dec 26, 2010 | Computers & Internet
I have DG41RQ motherboard. when i connect it with local internet switch after few mins window crash with blue screen. what should i do?
if u are using dial up modem for net then it is because of conflicts between the drivers!! reinstall the drivers and check BIOS configurations!!
if using LAN then see lan card drivers!!
reply in detail about the problem if persists
Jul 10, 2010 | Intel DG41RQ Motherboard & Core 2 Duo...
Intel D101GGC Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
