Question about Saws
Rexon manual cannot get the bolt off which holds the blade in place on my Rexon M2500A saw. It wont move. Any suggestions please.
  • 2692 Answers
SOURCE: I have a ms 150 miter saw that a relative gave
Jam a piece of wood between the blade and the table to stop it from turning while loosening the bolt. Circular saws never had locking mechanisms until recent years.
Posted on Mar 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: bandsaw blade keeps coming off Rexon BS 10
Unplug the saw and take the covers off the wheels. See if any of them show excessive end play or deflections when gently racking them from side to side. You may need to shim the wheels. Ideally, you want them all to track in the same plane, and you can check this with a straightedge.
There should be a tracking thumbscrew locked with a wing nut or some such on the back of the upper wheel. Put the blade on so it rides in the center of the tire, (move the guides out of the way if need be until you get the blade to track correctly), and turn the wheel by hand to see how the blade rides. That way you can make adjustments before it pops all the way off. By moving the bolt on the back of that upper wheel in or out you adjust the pitch of that wheel and change the way the blade tracks...
After you get the blade tracking smoothly under tension, you can move the guides back into position to support your blade during cuts.
Posted on Apr 20, 2009
SOURCE: stuck blade
I looked for a picture of this saw -- couldn't find one. When you wrote that you put the blade down on a 2x4 that sounds like a chop saw. In which case the balde is attached to the motor shaft.
A torch is kinda extreme, but if you do it safely & quickly it might work. If the blade is on the motor shaft, you don't want too much heat to get into the motor.
You don't want to heat the blade. Heat the nut only -- the nut will expand more than the shaft and perhaps break loose. I wouldn't heat it more than 20-30 seconds and make sure the flame is directly on the nut. Also make sure all flammable stuff is out of the way (like sawdust).
I wouldn't expect the heating to allow you take it off by hand -- you'll probably have to try all the brute force measures again -- and remember the left hand threads.
Posted on Apr 22, 2009
al_kupchella
  • 843 Answers
SOURCE: Blade guide bushes melt/wear with hard wood
If these bushings are getting that hot, then you may have the wrong speed or a non-optimum blade. The blade pitch (number of teeth per inch) must be lower the thicker the wood is. If there are too many teeth trying to cut at the same time you have to push harder to get enough pressure to cut and that puts more force on the guide bushings. There are a variety of pitches available even for the narrower scrolling blades. If you have to move up to a wider blade, there is a little trick to help you cut a slightly smaller scroll radius - round off the back side of the blade with a sharpening stone.
Also, with oak, you may need to use a slower speed to keep the blade from heating up - although a hot blade will show up as more of a problem with the lower guide bushings only. Your saw might have multiple steps on the pulleys, allowing you to move the belt to a slower speed.
I hope this helps. Thanks for using Fixya. Good luck!
Al K
Posted on Mar 24, 2010
  • 178 Answers
SOURCE: trying to locate downloadable operator
U.S.A.--POWER TOOL SPECIALISTS INC.
684 Huey Road Rock Hill, SC 29730 U.S.A.
Tel: 1-803-980-7740
Fax: 1-803-980-7750
Http://www.tradesman-rexon.com
E-mail: custserv@tradesman-rexon.com
I'm sorry I could not find any downloadable information on this scroll saw, but I would imagine if you call or email the company above, they may be able to email you a PDF of what you need. Good luck.
Posted on Nov 21, 2010
REXON BS 10 .3 WHEEL BANDSAW 20 YEAR OLD , WHAT IS MAX BLADE WIDTH I CAN USE . THANKS
open it and measure the drive wheel width . only a guess but 1/2 in might be all
Feb 02, 2017 | Blade Saws
How do I properly install the saw blade in the Rexon 15" Scroll Saw. I do not have a manual?
I'm not familiar with the saw. I suggest you to contact the manufacturer of the saw. They can help you with that.
Sep 14, 2014 | Saws
Rexon 406mm Scroll Saw SS16SA
Submit your mnual request directly to Rexon.
Jun 17, 2014 | Saws
Rexon bandsaw BS12
Read these blogs http://bandsawblog.com/band-saw-wheel-alignment/
http://www.doityourself.com/stry/basic-band-saw-blade-alignment-and-tracking-procedures#b
Apr 12, 2014 | Saws
Searching for trunion table mounts for Rexon MBS 380S Bandsaw
I can't find any good supplier. I checked on the site ( bandsawparts.com) where I lastly purchased guides but they don't have parts for Rexon band saw . Try calling Rexon 01709 876611 . Hope that helps!
Aug 08, 2013 | Saws
Rexon tablesaw
Update on me trying to find a manual for the REXON TMS-10A saw:
I found a helpline sticker on the underside, a spares company based in south Yorkshire , UK, with a telephone number.which I called. They fixed me up with an emailed manual within seconds. Brilliant!
Here's the full contact details:
Rexonspares ltd
Unit 3,century park
Dearne lane
Manvers
Rotherham
South yorkshire
S63 5de
Tel: 01709-876611
Fax: 01709-876811
Web: www.rexonspares.co.uk
Jul 28, 2013 | Saws
Rexon planer parts
I found the following on the net Try them if you haven't already done so
Contact Details
Phone: 01709 876611
Fax: 01709 876811
Email: Sales@rexonspares.co.uk
Technical@rexonspares.co.uk
Apr 25, 2013 | Tools & Hardware - Others
Trying to locate downloadable operator manual for rexon scroll saw model # RM 411 maufactured in 1988
Tel: 1-803-980-7740
Fax: 1-803-980-7750
Nov 21, 2010 | Garden
Bandsaw blade keeps coming off Rexon BS 10
Apr 10, 2009 | Saws
Need operators (owner) manual for tradesman 8031
Hi Jim, See you have been looking for awhile and understandably so. I don't have a manual and don't know anyone that does. Tradesman tools are manufactured by Rexon Corp. and they have a US office. I do not know where you are located so I have included the necessary information for you to contact them and try to get your manual.
Rexon Corporation
684 Huey Road Rock Hill, SC 29730 U.S.A. Tel: 1-803-980-7740
Fax: 1-803-980-7750
Good Luck, This should Fixya!
Mar 20, 2009 | Saws
Saws Logo
48 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
