Question about Exercise & Fitness
Dyaco treadmill parts
I need a motor control board for my landranger ct100 tread mill where can i locate one and what is the coat
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
SOURCE: What does code 22 mean?
Error 22 - No Motor Pulses at Start Up
Description
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either
manual or program control, and the monitoring system has not received any response from the
speed sensing system indicating that the drive motor has started.
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
speed sensor and the speed sensor target is obstructed.
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Posted on Feb 12, 2010
SOURCE: I have a Lifefitness Treadmill model TR 9100,
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
Posted on Jan 12, 2011
SOURCE: Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Posted on Feb 25, 2011
Walking on tread mill is jerky. almost like some one keeps putting the break on
Hi There, have you lubricated the deck lately? does the belt glide easily over the deck with your foot pushing it and the power to the treadmill off? If the belt glides easily with your foot, but not when powered, you're motor control board could be about to fail. capacitors routinely go bad on these controllers over the years. You can find further help by emailing gregATbuyfitnessrepairpartsDOTcom
good luck!!
Feb 07, 2016 | Bladez Ion 9.9 Fold-up Treadmill
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
My tread mill stop working i have green light in the electonic board 5 small light not on
You need a new controller board. You can check your manual for how to order replacement parts. It will not be available on the New Balance website. It will actually be from an off-brand treadmill manufacturer that made the treadmill for New Balance.
Oct 22, 2012 | New Balance Balance 1500 Treadmill
My mot566 tread mill carl lewis keep say EO1
1) adjust the speed sensor, see the diagram attached, clean, and tigh the wires connector.
2) measure the input voltage motor, if there are the motor need repair
3) measurre the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram how the main board control the 90% of the treadmill.
God bless you
Jun 24, 2012 | Exercise & Fitness
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
The treadmill powers up but the belt will not work
the motor controller has failed and will need replaced
Aug 01, 2010 | Horizon Fitness Merit Fitness 725T...
I have a pro form xp 542 s tread mill and think it is the speed sensor that is bad but i dont know where it is located or what it looks like,can u help me?
You have a bad mtr controller- did u leave the item plugged in wall without surge protector-did the power go off at house and then come back on(clocks blinking 12 one day)?? if yes to both you had a surge, if no still your controller/power board( all in one board) is bad
Jan 06, 2010 | Proform XP 542S TREADMILL Drive Motor
When the tread mill is running at a set speed, it for no appearant reason speeds up super fast with no one touching any button?
The motor controller controls the speed of the motor. This part usually work or dont work but I have seen a few instances where it was just going bad.
Jun 05, 2009 | Weslo Cadence 60 SE Treadmill
Error codes
error 1 is many times a speed sensor error. Make sure the speed sensor is in place, working and sending signal to the motor control board.
Jan 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
