Question about Panasonic TCP42C2 42 in TV
NO SOUND SPEAKERS NOT WORKING - Panasonic TCP42C2 42 in TV
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
No sound from speakers
Test the speakers by plugging them into something you know has a jack that works, like an iPod or MP3 Player. If the speakers work on that then the issue is with your computer. If it does not work it may be the speakers. Make sure all the plugs are securely connected for both power and sound. If the speakers do work make sure that the computer isn't muted. If the sound is on try using a different port like the headphone port. See if sound comes out of the speakers then. If it still isn't working you may want to try uninstalling the sound drivers and downloading the latest ones to install.
Mar 29, 2011 | Dell A215 Computer Speakers
Sound speakers not workin but headfones workin
plz check the speaker with other computer if the speaker is ok then the problem is with your sound card.
Jun 25, 2009 | Acer Aspire 4720 Notebook
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
NO SOUND FROM SPEAKERS
HI Surthi
First thing came basic, check your speakers with other PC, and see if work correctly, then use the software control volume to see if not set to "mute" connect the speakers to the right slot in the sound card, sometimes according to the colors, usually green. see if you have installed the drivers for your sound card.
good luck!
Carl
Nov 05, 2007 | HP (PP036AA) Computer Speakers
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Panasonic TCP42C2 42 in TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
