Hotpoint Ultima WMUD 1043 - Error F05
Have removed kickboard and cleaned filter. Put machine on "Pump Out" but water remains in drum, no spinning happens and F05 reappears after 2 mins. Any ideas what to do next? Thanks
  • 51 Answers
SOURCE: Hoover AAA 160 Error 3
If you are certain that all pipes are clear, then you may wish to check the pressure pot & pressure switch ( & small hose joining the two as this could be telling lies to the program unit. If the machine is emptying but the switch fails to read the level correctly, it can cause the same sort of error problem. Pressure pots can fill with the "grey soap gunk" and switches pressure are a reletively common fault also. Good luck
Posted on Jul 28, 2007
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
Posted on Dec 08, 2007
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
rickead1
  • 1998 Answers
SOURCE: Hotpoint Ultima wash machine has error code F05
hello you have a jammed pressure switch on full it says so if removed the blockage have u tired replacing the pressure siwtch. You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Obviously the machine will need isolating first and the switch will need removing from the machine. it depends how handy you are if you can change brakes in a car this will be an easy task to replace hope this helps please remember to rank how this helps you and if i can help in any other way please write me back have a great day
rickead1
Posted on Aug 17, 2010
Testimonial: "Thank you for the quick response, since posting I have done a little more research and believe you are 100% correct. I"
  • 118 Answers
SOURCE: have an hotpoint ultima wt940
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Posted on Feb 21, 2011
F 05
Hello,F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Thanks
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fo5 flashes on hotpoint ultima washing machine
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution,
Thankyou.
Feb 01, 2010 | Washing Machines
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint machine has filled with water and won't empty error F-05 FLASHING before that all lights were flashing ??
Error F05 means pressure switch jammed on full.
Remove large black hose on bottom of drum.
Fit back and test
Jan 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Locate and remove large black hose fastened to bottom of drum.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Error code f5
I think you mean error F05 for a Hotpoint washer.
it means the pressure switch is jammed on full, check pump is working o/k and if there is a filter, remove and clean it, see user instructions..
If still no joy, then you will have to call an engineer..
Plz rate this solution.
Thanks.
Jan 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
