H57h am2 manual
Upgraded pc ddr3 ram from 4gb to 8gb using all four dimm slots and pc crashes dumping ram and blue screen appears restarting pc
  • 47 Answers
SOURCE: physical dumping memory...
Try to increase your virtual memory.  This may help you some.
Posted on Oct 27, 2007
dbarchitect
  • 150 Answers
SOURCE: upgrade ram
This should work for you.
Photos and Motherboard Layout
Please rate as FixYa! ThankYa!
Posted on Dec 01, 2007
Make_toast
  • 10 Answers
SOURCE: reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Posted on Apr 21, 2008
service_TVCS
SOURCE: Memory Upgrade
I believe the max you can go with per slot is 1gb.
This is copied from the Acer site:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM
http://www.memoryx.net/acerxtd1024.html
Posted on Jan 31, 2009
jonb3838
  • 237 Answers
SOURCE: Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Posted on Mar 29, 2009
Max ram memory for chili green 556E notebook
probably 8gb if your computer is ddr3 but if it is ddr2 then max may only be 4gb
Jul 03, 2014 | EliteGroup ECS G556 Notebook
I upgraded my memory to corsair 4gb 1600 ddr3 ram on my samsung rc410 laptop. BIOS is showing the 4gb but windows is not booting up, it is showing blue screen. i have tried in another dell laptop but it...
i would take out all ram , then just put in the 4gig
there is 2 slots for ram
if that is the same then windows may have crashed , try getting into safemode by pressing f8 after bios
Oct 30, 2013 | CORSAIR 4GB - PC12800 RAM, DDR3, 1600MHz,...
Can I add 4gb more RAM
see:http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=5295969&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03536888-9%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
probably no, 32 bit systems have an under 4Gb limit. looks like 2 memory slots 1,2,4 and 8Gb supported.
Memory upgrade information
  • Dual channel memory architecture
  • Two 240-pin DDR3 DIMM sockets
  • Supports DDR3 DIMMs
    • PC3-10600 (1333 MHz)
    • PC3-12800 (1600 MHz)
  • Non-ECC memory only, unbuffered
  • Supports 1 GB, 2 GB, 4 GB and 8 GB DIMMs
  • Supports up to 4 GB on 32-bit* systems
  • Supports up to 16 GB on 64-bit systems
Aug 29, 2013 | HP Pavilion P6 Intel Pentium Processor,...
Cant upgrade to 8gb
The spec for this model shows "4GB DDR3 memory" without mentioning the pin/speed specs. There are two types of ddr3 rams. one is 204 pin 1066 bus and others are 240 pin 1333 or more. By the config it has, i guess, it should be 1st kind of ram which is not what you would get if you ask for usual ddr3 ram. You can compare both ram side by side to see if the older one has less connectors. if so, you have to buy proper ram.
eg, here is an example link for that 204pin ddr3 i was talking about
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233080
Apr 02, 2013 | Acer Black AX3400G-U4802 Desktop PC with...
Laptop currently has three 4GB RAM sticks, is it possible to use another 8GB stick to upgrade it to 20GB?
It should. But RAM slots have a maximum RAM per slot. Have you checked with manufacturer manual to see what the max ram per slot is? And the max ram per motherboard matters too. Your mobo will only support so much ram.
Dec 07, 2012 | MSI Gt70 0nc-051us
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)
Maximum Memory: 32GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
Aug 19, 2012 | Gateway Desktop / Intel Core i3 Processor...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Mar 05, 2011 | ASUS U50F Notebook
I need to know which is the part number of the DDR3 bulded iside the Lenovo ThinkPad Edge 15 0301-GQG leptop?
Manufacturer Part: 55Y3706
2 GB (installed) / 4 GB (max) - DDR3 SDRAM - 1066 MHz - PC3-8500 ( 1 x 2 GB )
So you need DDR3 SDRAM at 1066Nhz PC3-8500
If you are running 64bit Software then upgrade to 8GB (2 X 4GB sticks) otherwise your OS may not recognise any more that 2 MB
c0006679.jpg LenovoMemory - 1 GB - SO DIMM 204-pin - DDR3 - 1066 MHz / PC3-8500 - 1.5 V - unbuffered - non-ECC Manufacturer Part: 55Y3706
Jan 04, 2011 | Computers & Internet
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Computers & Internet Logo
David Payne
David Payne
