Question about Scosche Industries Scosche Mazda 2007 Cx7 Dbl Din Install Dash Radio Kit
Need to reset car alarm on mazda cx7 after battery change
Alarm wont shut off after battery change need to know how to reset alam so car will start
2007 Mazda CX7 factory alarm started going off on it's own..just had it at the dealer to have PCM factory recall taken care of.I had to undo the negative side battery cable just to shut off the audible...
looks like they didnt fix the computer-nevr bring a car to a dealer-techs are inxperiencd---get a data stream run thats displays values so a good mech can decyfer--may need that computer reflashd w factory gear
Nov 10, 2013 | Cars & Trucks
Mazda cx 7 battery problems
Check or have the battery's state of charge tested with a voltmeter. If the battery is low on charge, have it charged up. If all connections on battery and starter are clean and tight,, car should start. If you get it started and the alternator/battery light stays on with car running, there is a charging system malfunction. Have the alternator tested, in that case.
Jan 03, 2013 | 2010 Mazda CX-7
My alarm is on but wont shut off
Use only your key to unlock, open the door, then lock and unlock the door again, then get in and start the car. This will reset it. Also, you can disconnect the battery and turn on the light to make sure you drain all the power from the system then reconnect the battery. And you might want to check the battery on your remote.
Apr 06, 2012 | 1996 Mazda MPV
95 jetta replaced battery and the alam system wont stop
reset alarm, if you dont know how, get back.....soon
Sep 16, 2010 | 1995 Volkswagen Jetta
My alarm will not shut off, and because of it my car will not turn over/start, I turn the key to the right in the key entry as I am suppose too and it doesnt work to shut it off. Because of all of this I...
well depending on who wired your alam hopfully for your sake everything is wired properly if not you may want get somone who knows what there doing to look at your alarm and possible do a rewire bit before you do that check you battery on your vehicle make sure it doesnt have dry cell that is if it is not a maintaince free battery if it is then you still want to have it check to insure that it is holding a charge if it cannot hold a charge then in some cases than can trigger your alam to what it is doing because of surges in electicity due to the lack or inablitly of the battery it self not being able to stay in a constant state which is what you want
Oct 30, 2009 | Vehicle Parts & Accessories
Changed battery and the alarm will not shut off, or the car won't start.
take +and_ cabels off now turn on key now put cablels back leave key on the whole time untell done
Jul 26, 2009 | Toyota Camry Cars & Trucks
Scosche Industries Scosche Mazda 2007 Cx7 Dbl Din Install Dash Radio Kit Logo
24 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
