Question about Genius Radio Communications
Genius hs 980bt connection
Genius hs 980bt connected with I pad but not able to connect it with Nokia or Samsung
SOURCE: connecting motorola hs 815 headset to sony ericsson w 810i mobile phone
Go to blutooth, my devices, add new device, the phon are now searching for a headset.
Activate the headset, by clicking and hold the volumebutton one way, and then after click and hold the big "answer" button.
Hold both for 3 sec, then release the volume button before releasing the "answer" button!
The headset wil now lit up, and a blue light wil glow continusly.
Now you can search for new devices, like I described in the beginnging.
With love, Henrik
Posted on Jan 25, 2008
SOURCE: How to connect SAMSUNG bluetooth headset SBH 650 to my Nokia e71
When the pairing process between the E71 and SBH650 starts, try immediately to hold down, or press every half a second, the central 'call' button on the SBH650 - to force the SBH650 to think it is pairing with a new device. It took me 5-10 min of playing about in a similar situation, but eventually the SBH650 cleared it's 'memory' and the '0000' pairing code worked with another telephone...
however, I have never managed to pair the SBH650 with OS 3.0 upgraded ipod touch 2nd gen.
Posted on Jul 22, 2009
  • 7 Answers
SOURCE: mi genius hs-04s's mic does not work...everything
replace your mic
Posted on Mar 16, 2010
Testimonial: "hahahahahahaha ok...best solution, i'll do it today"
  • 7 Answers
SOURCE: hs 1200connect to xbox360
there are series of problem in xbox which can be solved without much technical knowledge your problem is one amoung that ........ your problem belong to that so dont worry i will give you the link to download the repair guide that will help you a lot Click Here
Posted on Aug 22, 2010
charlesharun
  • 174 Answers
SOURCE: When i try to connect
First, examine the connection receptables on the PS 3. For example, inserting the head set pin into wrong PS 3 connection receptable would not produce any sound discussable.
1. The PS3 device has several connection receptacles either for video audio output or video audio in put.
2. Video audio out put only gets sound and movies out of the PS3 device to be projected on to another device, e.g. projector, TV screen or Any out put devices.
Note: You solution is to connect the headset to the out put indication area keeping in mind not to connect to the Video receptable, else would be trying to output video signals to the headset.
Caution: You do not want to connect the headset pin to the Video Audio Input receptacle areas, because, you would be trying to send signals into the PS3 device rather than get sound out.
Important Notes;
Getting signals out of a device like PS3 is inserting the headset in this case, pin connector would be inserted in the INPUT Area; keep in mind your are tryinng to hear sound, SO connect the HeadSet PIN to AUDIO reception area on the PS3 device
The same techniques is achievable for all equipment requirign connection.
REMEMBER TO PHYSOCALLY LOCATE THE INPUT to OUTOUT area on the device.
Give the following proccess a try.
contact the manual of the PS3 device refering to the device connectivity chapters or
Systems diagnostic or malfunction chapters for technical material when required.
Posted on Dec 02, 2010
Nokia HS-20 AD-41 broken who can repair please help me with a diagram
If the wires are open or the connections are visibly broken then the connections can be mended. But if there is fault in the earpieces then I suggest that cost a new one must be checked before you think of getting this repaired.
Mar 14, 2011 | Nokia Music Headset HS-20 & AD-41 Headset
When i try to connect my genius hs-03u's to my ps3 it doesnt work is there any way to make them connect
Important Notes;
Dec 02, 2010 | Genius HS-03U Headset
How to connect nokia N95 to bluetooth HS-56W?
You need to pair the device first.Check if it is picked up from the other device and you may need to check its manual for a default code for pairing but that differe from devices..Hope this helps.
Oct 05, 2009 | Nokia HS-56W Wireless Headset
What is the password to connect handsfree with mobile
The passkey should be four zeros: 0000
Mar 27, 2008 | Lands Phones
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Radio Communications Logo
24 people viewed this question
Top Genius Radio Communications Experts
TO Lady
Tom Chichester
Clive
Clive
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
