LG Fuzzy Logic 13kg, T1308TEFT0, When switched on an "F" is displayed and no program engages. the drum is supposed to turn momentarily when the water is weighed. What could be wrong?
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
Dissolu
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
  • 4 Answers
Place a piece of magnetic material at the edge of the lid, for the wf-s6697tc model.
Standing in front of the washer, it is slightly off centre to the right (at the edge where the lid covers, space between the wording speedy soak & fuzzy). If you pay attention to the lid, you might notice some brownish rust stain.
This is where they place the magnet.
Posted on Sep 07, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
there is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
Nov 24, 2016 | LG Washing Machines
Fuzzy logic washing machine 12.5kg. What does PE code indicate?
PE pressure level switch error. This monitors the water level. It has a tiny hose connected from the drum. Could be blockage in the hose.
Feb 16, 2016 | LG Washing Machines
Lg fuzzy logic washing machine
Sounds like it's stuck in rinse, try unplugging it for 5 mins then power up turn the selector to normal cycle and start, see what happens. There might be a reset cycle it has to do. Or a programming mode. LG 18002430000 customer service
May 15, 2014 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Where is the water level switch located on the LG fuzzy logic
The water level switch is always at the top of the machine. All it is is a tube that goes from the bottom of the drum to the switch. The water rising cause air pressure to increase in the tube and it presses on a diaphragm, which pushes a micro-switch. It is round and slim, with one pipe and two wires. It is either fixed to the case inside at the rear, or hiding in the console. See the videos. Sometimes the pipe splits or leaks air, so you need to test the switch. Make sure you unplug it.
water level switch located on the LG fuzzy logic Google Search
Feb 21, 2018 | LG WFT1071TP Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
