Question about Able Planet Audio Players & Recorders
Chirping noise I have noise canceling headphones that recently started making a chirping noise every 4-5 sec. This happens whenever the headphones are turned on, whether or not they are plugged into a source.
    New Friend:
There's probably a bug in your ear buds
Posted on Nov 17, 2013
  • 13433 Answers
SOURCE: headphones
Please ask someone else.
To get the best support you could go get the premium assistance.
Or you can keep asking around, I don't know how to solve your problem.
Please leave this as unrated / not rated. Please don't rate the solution.
Thanks.
Posted on May 19, 2008
  • 1138 Answers
SOURCE: plastic strip on headbank broke off. this has boze
Check this site:http://www.my3cents.com/showReview.cgi?id=14258 Try www.Bose.ca or www.Bose.com
Posted on Oct 21, 2009
SOURCE: I am trying to find a source for the user's manual
You need a noise reducer manual?
Posted on Apr 22, 2010
Grubhead
  • 5309 Answers
SOURCE: covering coming off two sets
Try this site
http://www.jntworld.com/catalog/index.php?cPath=21_1002&currency=gbp&osCsid=c5b2f0de48c59564afb36dfebba513ac#tabbed_box_1
Posted on Jul 05, 2011
SOURCE: My turtle beach x4 headphones make a loud
I SOLVED IT :DDD just hold the tone and effects button on the x32's omg
Posted on Dec 13, 2012
Chirping noise
The cost is too great to repair.
Oct 18, 2013 | Logitech Audio Players & Recorders
Maytag electric dryer, lights flash, chirping
I had this happen with a maytag washing machine. The repair guy replaced a board and it worked fine. I'm afraid that's what happened here.
Nov 13, 2012 | Maytag Dryers
My QC3 make a loud whistling noise like a tea pot is boiling. I have changed my Ear Cups but thats it. I thought at first there was air entering from the small holes or that my battery was almost dead....
that happened to me when i was at the beach and had wind blowing. it stayed for several days but it seems to have gone after it was left with the battery disconnected for a few days .i would get them replaced under the Bose replacement program for $100 us
Mar 07, 2011 | Bose QuietComfort 3 Acoustic Noise...
My 1997 Malibu is holding up very well. Recently, I have noticed a slight chirping noise whenever I idle (especially after starting the car) and when I accelerate to about 45 or 50. It is NOT a whine...
Remove the serpentine belt notating the direction of travel. Start the vehicle long enough to confirm the chirp is either still present or it has stopped.
If the chirp stops manually spin all the pulley by hand to see if you can duplicate the sound. If nbothing else is making noise and the belt is in good shape put the belt back so that it travels in the opposite direction. If the noise persists replace the belt. If the noise goes away see how long it lasts. I have had many that have not returned after rotating the belt.
One other thing you can try is putting a small dab of di-electric grease on the belt, with the engine off of course. Spread the dab around a little with a finger, again with the engine off. Start the vehicle, give it a couple of seconds to let the grease work around the belt. If the noise goes away replace the belt.
Nov 14, 2010 | Chevrolet Malibu Cars & Trucks
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
Dryer is making a high pitch noise while operating, it is fine for about 30 sec. and then it starts to chirp.as if something is rubbing.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 16, 2010 | LG DLG3788W Gas Dryer
Abs brakes chirping noise, when pedal depressed,
worn out brake pads and slightly warped rotors. Most brake pads have small steel tabs that touch the rotor at a 90 degree angle when it is time for replacement. if you keep driving on the worn pads, it will stop chirping but that just means the tabs (also called wear indicators) have broken off and repair is about to get very pricey.
Feb 28, 2010 | 2001 Mitsubishi Montero
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
Chirping birds and screaching sound
Check to be sure there is the correct amount of preload on the front wheel bearings. Too loose or too tight will give you strange noises. Also, you may have a calibur hanging up or retracting too slowly. It causes the brake pad to stay in "Light" contact with the rotor and cause noises too. This could be an intermitten problem.
Good Luck
Feb 28, 2009 | 2002 Chevrolet Express
137 people viewed this question
Top Able Planet Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Able Planet Audio Player and Recorder Expert? Answer questions, earn points and help others
