Remove drawer I have item stuck behind drawer on my tool box how can I remove drawer to get it
    New Friend:
    Problem Solver:
  • 6 Answers
1]
If it is metal the draw could be out of alignment, tap it with a hammer to realign the travel action. As draws jam if not run squarely as they are designed to. If needed, use a small wood block to protect the surface of the drawer. Do this by placing the block on the draw face and hitting the block to realign the draw. This method means any damage will be limited to the wood block. But be sure of the draws design as hitting the wrong area will just tighten the draw.
2]
If the draw is metal and corroded it may have to be loosened with CRC lubricant first for a hours/days. Use the same technique, with the hammer if needed. [if the hammer is in the tool box, improvise] Talk to a hardware specilaist about the lubricant or go the CRC site to get the right type; http://crcindustries.com/globalhome/
3]
If it a wood or plastic tool box the same principles apply. Just swap soapy water for 'CRC' using a spray bottle on a plastic draw as a lubricant. For wood the best lubricant is powdered graphite.
4]
If all else fails your local car mechanic or a tradesman should be able to help.
Posted on Nov 17, 2013
2007 Pontiac Montana - How can you recover a lost item that has fallen behind the small flip down drwyer, near the floor of the centre dashboard console?
its easy, open the flip door part way and you can just pull, the tray will pop off the plastic hinges. when you are done looking, just pop the tray back on.
Jan 09, 2014 | 2007 Pontiac Montana
Need to remove a china cabinet drawer
Instead of trying to remove the drawer, try opening the drawer part way and use a vacuum cleaner hose (with the vacuum turned on) to snare the napkin and extract it. If you have one of those crevice tools (the long flat attachment) you can probably pull the napkin out without it getting sucked into the vacuum. I am assuming this is a cloth napkin?
Nov 28, 2013 | Universal Home
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
Kenmore front load washer is leaking from dispense drawer, cleaned entire drawer thoroughly and still leaking
Remove the soap drawer and look for a sock or other item that might have gotten stuck in the hose
Nov 05, 2009 | Kenmore Elite 45986 Front Load Washer
Unable to close the bottom oven drawer (Kenmore)
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
Feb 23, 2009 | Kitchen Ranges
Paper drawer is stuck open?
there is a piece of paper stuck behind the paper drawer, remove the drawer and then look inside, also open side panel and you may be able to see part of the paper there also .
http://www.websitetoolbox.com/mb/copierquestions
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
