The remote sensor is not working in the TV unit
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
It can be replaced. Contact any service technician.
Posted on Nov 17, 2013
The remote sensor in the TV unit is not responding
Check the remote control for its infrared emission first. If it found OK, check and replace the remote sensor inside the TV. To get more details, http://electronicshelponline.blogspot.com/ Testing procedure to remote control is given in detail. 5861f1e7-87a3-433c-a8c7-016dc4787f6c.jpgec36d179-61eb-46d0-b8d0-578cf88fc7b0.jpg
Remote sensor will look like this.
Nov 17, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Can't get tv remote to work
does the remote controller that you have been use is the original remote of the tv?. if yes tried to replace the battery, if still doesn't work tried with camera trick just to ensure if the remote controller work or the IR sensor of the tv was not working. just let me know if you know how to test the remote controller. now if you are using the universal remote controller make sure it was programmed properly with in the tv unit.
Sep 02, 2012 | Televison & Video
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp
May 14, 2011 | Televison & Video
Not functioning on my tv sensor
need nmore info then that. are u saying that the remote control is not working with the tv or are u saying that the controls on the set is not working . ok lets say the remote is not working 99 times the problem is the remote control unit. the best way to find out is. if your tv is a newone 1 -2 years old u could take the remote to best buy and see if it will work on a nother tv set there. if not it is your remote problem solved.if it does work then i could be the sensor but u need a scope to see the rf signal from the sensor i have only change 2 sensers in my 30 years working in electronice service field. let me know marty
Oct 13, 2008 | Televison & Video
Remote Control not working for MW24FM3 Toshiba
I have the same problem with my unit. I use the original remote and my Tivo remote. Both stopped working at the same time. Ocassionally they will work for awhile then stop. They always both work or both don't. Therefore it must be the TV; likely the sensor or something connected to it. Sorry I don't have a solution. Guess I need to take it to the shop.
May 07, 2008 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
The tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Feb 12, 2008 | LG 42LC2D 42 in. LCD HDTV
SHARP T.V. not responding to remote, but remote isn't broken
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Remote sensor in the TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Nov 14, 2005 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
