Will not power up
Just removed from box did not start then tried to charge but it is still charging will it stop when done and how long should I charge the new tablet for?
  • 29 Answers
It will stop when it is done look for a light will change from red or orange to blue or green indicating that it is finished wait at least an hour before attempting to turn it on it needs a full charge before you use it
Posted on Nov 17, 2013
My Acer Aspire 7750g-6857 will only charge when in sleep, hibernate, or shut off. When i plug the charger in, the power light will flash and it won't charge. Please help..
try to remove the battery, plugged into charger and see what does the icon shows. right click the icon and select power option try to restore all settings to default. if this would help.
thanks
Mar 31, 2014 | Acer Aspire Computers & Internet
It will start to charge then stop
A bad battery will not charge, if it done it's done. If the battery is old it should be replaced by a battery of the same power specsand type. BEWARE of cheep online batteries.
Nov 08, 2012 | Dell Latitude D610 Notebook
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
I have a Compaq V6000 laptop. When I try and start it up the fan starts, the disc drive makes a couple of the usal start up noises. About 15 seconds later it just stops and all lights go out. Can Anyone...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 07, 2010 | HP Compaq Presario V6000T PC Notebook
I have a 2004 Suzuki Marauder VZ1600. I was out riding last night and made several stops. When I stopped at my last stop and tried to start the bike it was dead. I put a jump box on it and it started right...
Most bikes require that your battery be in goo condition in order to run. They actually use the battery as part of the ignition circuit. So if your battery is completely dead it will drag your ignition circuit down.
Recommendation: Remove your battery, charge it and/or get it tested.
Secondly, if your battery checks out as being good, the only other thing I could think of it being is your charging system. That being comprised of a stator and a voltage regulator. These are semi expensive parts so, once you get past the battery check, I'd advise you to either get a manual for your bike, and some testing equipment (if your mechanically inclined), or take you bike to a reputable cycle shop and have them check it out. This way your not replacing good parts trying to track down the problem.
Good Luck.
Apr 04, 2010 | 2004 Suzuki VZ 1600 Marauder
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
My battery has no power and wont take a charge
Check that a door switch is not open, or that an interior light was not switched on and left on, either at the light, or at the headlight switch.
If all your trying to charge the battery with is a trickle charger, then it can not charge the battery and light the light too.
Jan 29, 2009 | 1984 Ford F 150
Battery charging problem HP DB6000 series
They either didn't replace MB or didn't replace charging IC on MB. Needs to be done either.
Jan 04, 2009 | HP Pavilion dv6000z Notebook
133 people viewed this question
 Grubhead
Grubhead
