Question about Garden
How do I loosen the modules on top of spark plug
    Sergeant:
  • 337 Answers
Jeffrey the module should just pull off.
Posted on Nov 17, 2013
It's about Husqvarna 345 chainsaw. I would like to know the resistance value between spark plug wire and blue wire from ignition coil, and between spark plug wire and the ground and finally resistance...
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Nov 21, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Saw feels like it,s out of timing, pull rope hard to pull with plug in.. pulls easy plug out maybe trying to fire to fast
Check the air cleaner for plugging. Remove the spark plug, open the throttle with the choke off, turn the machine upside down and pull it through smartly several times until the excess fuel is expelled. Dry the spark plug interior insulator and test for spark--it should be blue and snappy (plug gapped 0.020"). If weak looking, try a new plug first, and if still weak, remove the left engine case to expose the flywheel and ignition module. Turn the flywheel magnets under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the module gap doesn't close up at any point. Reassemble and test again for spark. If now good, try for engine start. Hope this helps!
Nov 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Won't start
Assuming the engine has good compression, remove the spark plug and check for spark--it should be blue and 'snappy'. If no spark, try a new plug gapped at 0.020". If still nothing, you may need to replace the ignition module which is located behind the left side cover/starter. Use a thin business card for a pole gap gauge, turn the flywheel magnets under the module, and loosen the module screws to allow the module to contact the magnets through the gauge. Try for spark again before replacing the module. If you got good spark in the first test, then pour some fresh fuel mix into the plug hole and try for start--if it pops a few times, then look to the fuel/carburetor system for service. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. If the saw has seen considerable service or been storage for some time, the carburetor may need to be cleaned inside and out. Hope some of this helps!
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
350 16" inc. chain saw want crank with new plug or starter fluid
Check for spark at the plug (gapped at 0.020"). If nothing, remove the left side case and starter--this exposes the ignition module. Check the pole gap with a thin business card for a gauge. Turn the flywheel until the magnets are under the module poles, insert the card into the gap, loosen the module screws and let the module contact the magnets. Tighten the screws, rotate the flywheel somewhat to release the card and recheck for spark. If still nothing, try removing the stop-switch wire from the module and try for spark again. If nothing again, replace the module. Install as above. Hope this helps!
Sep 21, 2010 | Husqvarna Chain Saw 20" Bar
It wont fire up i used sandpaper to clean it and still wont fire up no spark eaither but spark plug sarts on a lawn mower but its a pockit mini bike
Sandpaper makes a poor cleaner for spark plugs. The critical point is the condition of the inner insulator--if black and oily, it will tend to shunt the spark over the insulator instead of jumping the electrode gap. The problem that you are having seems to centered around the spark generating apparatus. If it is a self-contained module, check the module pole gap with a thin business card for a gauge. Rotate the flywheel magnets under/over the module, insert the card into the gap and loosen the module mounting screws to allow the magnets to contact the module, then re-tighten the screws. Rotate the flywheel somewhat to remove the card and recheck for spark. If still nothing, you may need to replace the module. Hope this helps!
Aug 09, 2010 | Garden
Poulon chain saw model 2175 no spark. What to check?
Remove the starter assembly and left side cover to expose the flywheel and ignition module after trying a new spark plug gapped at 0.020". Remove the ignition switch wire from the module and try for spark again--if still nothing, use a thin business card for a gap gauge between the flywheel magnets and the module poles. Loosen the mounting screws, let the module contact the magnets through the card, then tighten the screws. Try for spark again--if still nothing, replace the module. Use the above procedure to install the new part. Hope this helps!
Aug 05, 2010 | Poulan Garden
HAVE OLDER RANCHER 44 NO SPARK AT PLUG ATTACHED SPARK TESTOR STILL NOTHING NEW PLUG CONTINNUITY FROM SWITCH TO COIL BUT NO WAY OF CHECKING COIL OR BEYOND HARD STARTING BEFORE THEN JUST QUITE WHILE I WAS...
Remove the flywheel cover to expose the flywheel and the ignition module. Remove the ignition switch wire from the module and retry for spark. If still nothing, try using a thin business card for a gap gauge between the flywheel magnets and the module poles. Insert the card, then loosen the module screws--and allow it to stick to the magnets. Re-tighten the screws and rotate the flywheel to remove the card. Try again for spark. If still nothing, then replace the module. Install the new part as above. Don't forget the switch wire connection. Good luck!
Jul 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
CS-670 . Cleaned fuel tank , lines , carb. New
Check for blue, snappy spark at the plug (gapped at 0.020"). If weak or nothing, remove the flywheel cover to expose the ignition module. Check the module gap with a thin business card--turn the flywheel magnets under the module poles, insert the card into the gap, loosen the module screws, and allow the module to contact the magnets, then tighten the screws. Turn the flywheel somewhat to remove the card. Recheck for spark--if ok, try for engine start. If still no spark, remove the ignition switch wire from the module and retry for spark. If still nothing, replace the module. Install per the above instructions. Hope this helps!
Jul 06, 2010 | Echo Garden
I have a Poulan 2050 is there a setting for the the spark plug?
Use 0.020" for the plug gap. If the spark is weak looking, check the ignition module to flywheel magnets gap using a thin business card for a gauge--turn the flywheel magnets under the module, insert the gauge, loosen the module screws to allow the module to clamp to the magnets, the re-tighten the screws. Rotate the flywheel to remove the gauge, then make one complete revolution of the wheel while checking the gap--it should not close up any more than originally set. Recheck for blue, snappy spark. Hope this helps!
May 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Changing spark plugs 4cy engine ,location of the spark plugs
In the 2.2 they are under the top coil assembly,
which is a long plastic peice with the igniton module on the right end with wiring connector hooked in it.
take the 4 10mm bolts loose from the top and the 10mm bolt holding the cable on the right side of the engine head and carefully unplug the wiring connector on the module. this will let you lift the coils assembly
out after removing the 4 bolts. the coil assembly is pressed into the rubbers which will need to be pulled out after coil assembly removal. the spark plugs will be in the holes. Use a 6 inch 3/8 drive extesion with 5/8 inch spark plug socket. after loosening the spark
plugs if they don't come out with the socket use a stick mechanics magnet to remove, it will pull on the metal on the end of the spark plug while you gently
pull them up. this will save you time if they drop into
the hole. make sure they are completely loose.
when you put he new sparks plugs in after gaping them to specs put the long rubber in each hole,
push with your thumb smartly to seat on the plug,
you will feel a slight click, then put the coil assembly
on and push smartly not to crack it then keep it level as you put the 10mm bolts in. put all the bolts in a few turns before tightening them one at a time.
Feb 04, 2010 | 2004 Oldsmobile Alero
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
