Question about Panasonic Televison & Video
Wave multicolour in left bottom corner of Tv screen
  • 579 Answers
SOURCE: arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Posted on Jan 02, 2008
SOURCE: Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jun 03, 2008
SOURCE: blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Posted on Sep 06, 2008
SD Tech
  • 14553 Answers
SOURCE: Yellow arch on bottom left of screen. I have
OK, HERE are the instructions:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
if adjusting does not cure the problem one of the convergence chips this set uses and or a resistor are bad.
Let me know what happens and if you need more help let me know
SD TECH
Posted on Sep 30, 2009
Testimonial: "SD Tech was very helpful and responded very quickly - Highly Recommended!"
  • 20 Answers
SOURCE: tv screen has blue dots appearing on it
if you have blue spots in your picture on a sony grand wega you have a defectie optical light engine. The best solution is to contact sony and regardless of age , i beleive they covering this under warranty due to current lawsuit they are going through. Their customer service number is probably in the back of the customer instruction manual.
Posted on Apr 20, 2010
My LG tv has a problem with the screen where it looks like it's scrolling only in the bottom left corner.
Dec 04, 2012 | Televison & Video
How big is this tv
measure the screen only
from corner to corner
E.g. top right corner of screen to bottom left corner of screen
Sep 28, 2012 | Curtis-Mathis CM27101S TV
Is like a wave at the bottom of the screen and in
Convergence failure. You can get the convergence repair kit for your model at www.tvrepairworld.com which contains the parts and the CD with repair instructions.
Jul 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
There is a wave (color change) on the upper left hand corner of
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS,and all it resistors to solved this problems.Buy a convergence kit to fix it ur self.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost U $300 for parts and labors.
Feb 06, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Toshiba 50 rear projector tv
can you post a picture of what the picture looks like? I may be able to help if I can see what the picture is actually doing.
Jun 08, 2008 | Toshiba 50H82 50" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Wave at bottom of screen with green and pink shadows
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Open Questions:
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
