Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
On RCA HDTV wh74xy1 lamp blows out every three months
I have replaced the lamp three times in one year (which can be very expensive) I would like to no what keeps making the lamp blow out?
  • 158 Answers
Fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
Posted on Nov 21, 2013
ctf1800
  • 4402 Answers
SOURCE: 52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Posted on Feb 01, 2008
  • 154 Answers
SOURCE: RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Posted on Jul 23, 2008
SOURCE: I have a 50 inch RCA HDTV scenium model HD50lpw175
TRY THE BLACK LEVEL SETTING AND CONTRAST SETTING
Posted on Sep 04, 2009
  • 1779 Answers
SOURCE: What blows the fl231 fuse. On the RCA D52w23 TV?
Bad solder joints on the IFT.
Posted on Oct 21, 2009
Testimonial: "Thank you, That was exactly the right thing. I resoldered pins on flyback and now Doesn't blow the fuse."
Slinteriors
  • 8617 Answers
SOURCE: my 52" RCA HDTV Flat Screen TV
replace the deflection board. Your model uses the ITC222A deflection PSB-260 You can get the replacement deflection board from www.tvrepairworld.com
Posted on Apr 13, 2010
Hello I have a RCA HDTV m50wh74xy1 problem is I keep having to replace the lamp,each time I replace it (lamp) it might last for 3 months I would like to no what is causing the lamp to blow out
This could be difficult to find but most likely a grounding/shorting issue. I would start by checking the power supply and the leads coming off of that.
Nov 17, 2013 | Televison & Video
The screen is black and the bulb is't blowed
If your model number is HD50LPW175 and the power light is blinking 5 times thats telling you the lamp needs replacement before the set can power up. You can get the replacement Lamp assembly with installation instructions from www.tvrepairworld.com
Jan 29, 2013 | RCA HD50LPW175 50" HDTV
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
Does any offer a longer lasting bulb I replace it once a year from Mitsubishi
HI:
The normal usage time for lamps are 6500 hours, thats a little under three years depending on the use of the television, These lamps last longer when they are not turned off and on all the time. The constant heating and cooling prematurely wears out the lamp, also on Mitsubishi lamps have a filter on their lamps that geta cloged with dust from the exaust fan, causing heat to become traped in the lamp compartment which will cause the lamp to blow premautrely, using a compressor try cleaning this filter every 6 months or so for longer llamp life.
May 01, 2011 | Mitsubishi WD-73736 Television
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Samsung HLN617W 61 i
it is not related to the failure of the fan or color wheel by anything other then the age of the set..the lamp has a normal life of 4000 to 6000 hours and since your set is around 3.5 years old it probably has that amount of time on it..the lamp is consumer replaceable and many places sell them..the lamp number should be on a small sticker on the side of the set
Dec 02, 2007 | Samsung HLN617W 61" Rear Projection HDTV
No picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Oct 25, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Lamp problem or not?
2 years and three months but, what counts are the hours that it was on. Your software only really effects the way the TV interacts with HDMI inputs and really won't effect much else. The manufactures only expect 4-5000 hours on the lamp. Some go less some go more. You need to replace that lamp most likely.
Feb 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
