Question about Samsung Televison & Video
Gateway ping failed how do I fix that?
Wont connect to internet
SOURCE: Cannot "ping" 192.168.1.1 (default gateway)
1) yes, referring to the router's IP address.
2) I determined the IP addresses of all my computers and tried to "ping" them but could not "ping" any of them. I can "ping" the IP address of the computer I am working from but I don't think that helps in TS this situation.
3) I'm wondering if my router is fully set up correctly. Do each of the computers have to be "saved" in the router's settings?
Posted on Jan 12, 2008
  • 43 Answers
SOURCE: ping www.yahoo.com - FAILED
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Posted on Apr 13, 2009
  • 1738 Answers
SOURCE: my blu ray cant ping
Try shutting down your firewall on the router itself. Routers will block ping request and therefore won't let it connect.
Posted on Nov 14, 2009
  • 109 Answers
SOURCE: Can't ping Default Gateway (XP) From Windows 7
Make sure you are receiving a proper IP address from the DHCP server....If you run a cmd prompt (windows icon, type cmd and hit eneter, then ipconfig) you should see a 192.168.0.x address. If not, go to the control panel, network connections, manage network connections, and be sure that TCP/IP (V4) is set as auto-configure....
If you are sharing the connection through an XP computer, you will need to run the Internet and connection sharing Wizard on the XP computer, and transfger the settings on a disk to the Windows 7 PC. A simpler solution (assuming you are on a cable/dsl connection would to be to go to your local big box store and buy an Internet/Firewall router. It would also increase your security.
Posted on Dec 28, 2009
  • 12 Answers
SOURCE: gateway not pinging from dwl 3200 ap .
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Posted on Jul 02, 2010
I've connected my Router to switch and through switch i connected two wireless Netgear N150 router where my router is gateway. My Problem is I can ping from Laptop to Router gateway but unable to ping from...
The two wireless routers THINK they are directly connected to the Internet and they prevent the WAN side ports from being pinged so hackers can't find out you have a device on the Internet. The devices will let you to the Internet without any problems, why do you need to ping from the router to the WiFi routers anyway. all of that is your internal network....
One thing that might fix this is if you can put the WiFi routers in BRIDGE mode. Some routers will let you do that, some won't. Don't put the router that is facing the internet into bridge mode. hackers will be able to see your whole network.
Sep 12, 2013 | Linksys EtherFast Cable/DSL Router
Where can i find my gateway ping on windows 8?/
There may be a problem in your internet connection.You first read user manual whether it is possible to connect the blueray player with internet or not.If you cannot ping the ip address there may be a problem in it.Try to reset the modem and check ping for any ip address and website using the site Whoisxy.com .
Apr 02, 2013 | Lenovo Computers & Internet
Operating system: Windows XP Home Edition Model: Acer One Aspire Problem: PC sees wireless networks & connects but Internet Explorer &/or Mozilla don't get me on the internet.
please ping your router gateway,for seeing default gateway you take command prompt and type ipconfig, there you can see your default gateway then type ping gatewayip (eg: ping 192.168.0.1) if you are getting reply from that gateway your computer communicating with your router.If you are getting request timedout then there is a problen in communication.If you are getting the reply then you just ping google (ping www.google.com).getting reply the connection to the internet is fine.If not there is problen in internet connection in the router.
Jul 21, 2011 | Computers & Internet
It says it is connected to access point but internet cannot be found.
Check you connection by:
-checking connectivity to router
open command line and type :ipconfig" and hit enter
find entry called default gateway you need the ip it is set to
now in command prompt "ping GATEWAYIP" (replace GATEWAYIP with the ip from above)
If ping fails you need to check to make sure your router or adapter is not faulty. Or undo any static ip assignments you may have.
If it worked
try to run "ping 8.8.8.8" (this will test if router is routing to internet)
If it fails and the step above works you need to power cycle the router or replace if it dosen't work.
Now if everything works so far try this
"ping google.com"
if it fails you have a DNS problem you can fix this by useing goggles Free DNS server.
How to Link:http://code.google.com/speed/public-dns/docs/using.html
If that workes:
You may have a Internet explorer related issuse.
Fix by
Running a Virus Scan
Remove any IE toolbars
Clear all IE settings
Avscan:
http://free.avg.com/us-en/homepage
IE toolbars: and IE settings:
http://technet.microsoft.com/en-us/magazine/dd364987.aspx
Don't forget to Rate
May 10, 2011 | Linksys WUSB11 802.11b Wireless Adapter
My laptop will not connect to our wireless router at work. It says connected, but no internet access.
The laptop might be connected to your wireless router but is unable to connect to the internet
check if you can ping websites
- click on start > Run > type in "cmd" > in the command prompt type in "ping www.yahoo.com"
- if you get 4 replies the problem might be with your browser.
- if Ping fails try typing "ping 209.191.122.70" which is the IP address for www.yahoo.com
- if ping is successful then the issue is with your DNS server. contact your ISP to get alternate DNS
- if Ping fails try pinging the default gateway or modem IP (you can find the default gateway by typing IPCONFIG)
- if ping is successful then there is a problem with your internet provider
Also you should try disabling your firewall and runnning a virus/malware scan
Mar 30, 2011 | Computers & Internet
I have a samsung tv , and im setting up my INTERNET@TV , it ticks off everything but the Gateway Ping ! Please Help
If the Gateway Ping test fails, then your TV is not communicating properly with your Router or Modem.
To resolve this, follow these steps:
  1. Power off your TV, Modem, and Router.
  2. Unplug the power for your Modem and Router.
  3. Make sure the ethernet cable is securely connected to both your TV and your Router or Modem.
  4. Plug in your Modem and turn it on.
  5. Plug in your Router and turn it on.
  6. Make sure your IP Address information entered into the TV during the Network Setup matches the information from your Router or Modem.
  • If you are using an Automatic Setup (most users), skip this step.
  • If you are using a Manual Setup (advanced users), contact your network administrator to determine what the correct IP Address information is.
7. Run the Network Test again.
  • If the Gateway Ping test passes, but another test fails, click here to go back to the list of Network Tests.
  • If all tests pass, the TV is successfully connected to your network.
  • If the Gateway Ping test fails again, see below....
If the Gateway Ping test fails again, there may be a problem with your network setup. To determine if there is a problem with your network, follow these steps:
  3. Connect your ethernet cable directly to the TV and Modem.
  5. Power on the TV and run the Network Tests again.
  • If all tests pass successfully, then there is a problem with your Router setup. Contact your network administrator or router manufacturer for information on setting up your network.
  • If all tests do not pass successfully, there may be a problem with the TV. Connect another device (such as a Computer) directly to the modem.
  • If the other device connects to the internet, then the TV will require service. Click the Create online service request button below to have the TV repaired.
  • If the other device does not connect to the internet when directly connected to the modem, then there may be a problem with your modem. Contact your Internet Service Provider for help on troubleshooting your modem.
(from Samsung support)
Hope this helps. -Sa_Les_Ski
Feb 28, 2011 | Televison & Video
Hello. I have a unique problem. I have a Windows Vista home premium system that can ping to my gateway and other systems on the local network but can not ping beyond my gateway and can not browse the...
If you can PING your gateway, then there was no need for the 'WINSOCK FIX'.
Access the web-server "inside" the router, and look at the table of DHCP clients -- confirm that your computer's "wired" and "wireless" connections are listed, and that they have been assigned IP-addresses.
The router should have its own 'PING' interface, so try PING-ing to 'ns.watson.ibm.com' -- you should get output like:
Pinging ns.watson.ibm.com [129.34.20.80] with 32 bytes of data:
Reply from 129.34.20.80: bytes=32 time=126ms TTL=241
Reply from 129.34.20.80: bytes=32 time=103ms TTL=241
Reply from 129.34.20.80: bytes=32 time=91ms TTL=241
Reply from 129.34.20.80: bytes=32 time=93ms TTL=241
if your router has an Internet connection.
Oct 23, 2010 | HP Computers & Internet
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
I have the Samsung BD 3600 and the Belkin N router and fail the gateway ping. Help
if you are trying to ping the router from the outside internet, the ping function is probably shut off. If you are trying to ping the router from a local pc either the pc is not connected to the router network or the router network is not the same as the pc network (example: router gateway ip is 192.168.55.1 and your pc is looking for 192.168.1.1. Check the router gateway id. If you can get to the router, you are probably ok.
Send more info if you can't resolve the issue.
Jan 30, 2010 | Belkin Computers & Internet
Jan 11, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Televison & Video Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
