Ipod model a1199 4gb
Blacked out, wont turn on, how to reset/
  • 35 Answers
Check that the IPOD is fully charged. Plug it in to the charger and you should see the screen telling you how much charge it has. Check the slider on the top of the iPod. If it's a Classic iPod there is a switch to prevent accidental turning off or on. Slide the switch to the left and try again.
Posted on Nov 17, 2013
  • 3 more comments
  • Brian Brokaw
    Brian Brokaw Nov 18, 2013
    It\'s just blacked out, one day is just stoped coming on, I charged it for days on USB on my PC and a wall outlet, I can\'t get it to do anything at all, I dont really care about the old peice of garbage but I want all the music off it because my itunes account got hacked and wiped clean and all that music is only on this ipod. I am to the point where I just have to realise the thing is fried and quit messing with it but I dont like being defeated by apple!
  • Ian Brown
    Ian Brown Nov 18, 2013
    Have you tried connecting it to your computer? Download TouchCopy and run it. Don't connect to iTunes yet otherwise it will wipe the iPod if you synchronize. It's possible that the iPod works but the screen died. You can use Touchcopy to copy everything back to iTunes if your computer can see the iPod.
  • Brian Brokaw
    The computer does not even reconize the device, so your saying if it was just the screen then it should still connect to itunes? To just retrive the music on the ipod? It's doing a whole lot of nothing, just black as night no matter what i try. So since my PC don't reconize anything does that mean my music is non-retriveable? And thank you for taking the time to reply to my problem
  • Ian Brown
    You might like to try leaving it connected via the USB cable to the computer just in case it will charge that way. It might be a problem with the charger. Also, check your iPod charging cable itself and look for bent pins. If you can, try using another cable from an Apple device to see if it's a cable problem. I'd say there is still hope if we can reasonably assume that the memory is OK. If it's the battery, Apple do offer a battery replacement for iPods for about sixty bucks if it's worth that to you.
  • Brian Brokaw
    Brian Brokaw Nov 19, 2013
    I have tried leaving it pluged in for 2 days in my PC & in the wall, w/ its
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
IPOD 2GB Nano display doesn't work
try pressing the reset button on the ipod. if it still freezes, the ipod has problems
Jul 31, 2010 | Apple iPod nano
My ipod 32G touch onsly shows apple logo on the black screen. will not do anything when plugged in. I have tried to reset, return to factory settings and nothing works.
ipod help is near
  1. http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-troubleshooting-wont-turn-on-appear-hung-sad.html
Jun 05, 2010 | Apple iPod touch
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Ipod touch speakers wont work
You may need to reset
Sep 02, 2009 | Apple iPod touch
Apple Ipod Nano Chromatic Frozen on black screen.
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Aug 10, 2009 | Apple iPod nano MP3 Player
Ipod wont turn on and i tried reseting it
ok what i would sugest is leaving it for a little while and see if it repairs it self if not the on switch just flick it up really quickly try that a few times hold it and then leave it and then flick it up quickly that worked for me so it sould work for you.
Jan 02, 2009 | Apple iPod MA446LL/A MP3 Player
Black Ipod 30gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jul 21, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod black 80GB
do a reset
To reset your iPod:
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
May 30, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 1st gen black
"OK to Disocnnect" message is normal; not being able to turn on or off while it is connected to computer is normal. If these problems are happening AFTER you have disconnected the iPod from the computer, then it is a problem - you will simply have to reset your player - the reset method for your particular iPod is in your user's manual - you can get this manual from Apple's website if you have misplaced it.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
81 people viewed this question
 Grubhead
Grubhead
