Question about Proscan PS27500 27" TV
Proscan 27" tv
I pressed the power button and it starts to turn on and then it clicks off, and then it clicks back on again, thus turning itself off completely. Seems like a lot of static magnatism coming from the picture tube after it turns itself off the last time. Any suggestions?
  • 1 more comment
  • harpoon Oct 10, 2007
    I have not yet had the opportunity to check out the suggested solutions, but I believe he is probably right on with the suggestions posted. Thank You Very Much!
  • Gregw3 Nov 26, 2007
    I have the same problem with my Proscan PS36800HR. Now I cannot turn it on again.
    Is there a place where I can get it fixed?
    THX
  • Richard Gregor Jul 05, 2008
    same thing, switch on, then relay drops out and switches off
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Posted on Oct 07, 2007
SOURCE:
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
Proscan 27" tv
if you want to eliminate magnetism, you have to degauss the screen, if you don't know how to do that, here is a small guide for that: http://www.wikihow.com/Degauss-a-Computer-Monitor
but that strange shutting down its the transistor... so your best choice is to send it to a repairman to change the transistor..
if you try to do that for your self, you could even get shocked with the electricity contained in the tv... even if its turned off and unplugged..
Dec 22, 2007 | Proscan PS27500 27" TV
Proscan ps32600
PRESS AND HOLD THE POWER BUTTON UNTILL THE LIGHT CHANGES AND TV WILL COME ON
Jan 17, 2009 | Proscan PS32600 32" TV
Proscan
you might have a ghost in your house turning it off or some one is playing a trick and has another remote behind there back and is turning it off
Jan 14, 2009 | Proscan PS27125 27" TV
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV won't turn on
Practice visual acuity technique! Solder any/all bad connects.check power supply. Check tactil switches on front of set. Remove chassis,unplug all connectors,re-assemble,try again.
Sep 25, 2007 | Sanyo DS27910 27" TV
Proscan PS27500 27" TV Logo
226 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
