My son pressed a button on the loewe anaconda remote and now we cannot get any sound or picture, just a black and white blurry picture. SOMEBODY HELP!! PLEASE.
    New Friend:
  • 37 Answers
Please enter in factory menu by input the service menu code, find the correct service menu code for your television in http:tvservicemenu.blogspot.com
I hope you can fix your problem.
Posted on Nov 17, 2013
4 Suggested Answers
SOURCE: picture is now black and white
 First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable
 transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
  1. Weak signal or defect in tuner/IF causing loss of signal strength.
  2. Coler killer set too high (internal control) if it has one.
  3. Defective part around the chroma chip/circuit. Faulty color oscillator.
  4. Bad connections in area of chroma chip/circuit.
  5. Defective chroma chip (don't suspect this first just because it is probably very expensive).
A service manual or Sams', DMM, and scope will help greatly in attempting to troubleshoot this unless it is an obvious bad connection. Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Posted on May 08, 2009
SOURCE: my son just accidently pressed a button on the
TV powers on with no picture though
Posted on Aug 14, 2009
  • 9 Answers
SOURCE: My Loewe Aconda TV will not turn on - buzzing noise.
A very common issue with these sets is the flyback transformer fails. It is available from Panurgy in NJ and is a moderate difficulty fix.
I’m happy to assist further over the phone at https://www.6ya.com/expert/stanley_d05f392d8fafa669
Posted on Aug 05, 2012
I have a Loewe Concept 32 that makes a buzzing noise when switched on. The picture and sound are otherwise fine but a variable frequency buzz predominates
Check for any core loose [SMPS] transformer at its main power supply regulator board. Contact any service technician. This is a very dangerous part to touch. Gopakumar Gopalan Google
Jan 02, 2015 | Loewe Televison & Video
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
Loewe Planus TV is recognising Loewe remote control (red light on TV flashes when remote is used) but the remote functions do not work.
Hi can anyone help me enter the service mode on a loewe 4781zp the service manual says press set display button then in 1 sec press "M" but the set set remains on "Authorised dealer only" thanks John
Sep 22, 2010 | Televison & Video
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
No signal!
Hi Rabia,
It seems as if the Picture-in-Picture feature of your television is activated. Please take a look at the remote control and find the PIP button and press it, this should bring the picture into full-screen and allow you to hear the audio.
-SHG
Jan 14, 2009 | Loewe Televison & Video
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Rounded Picture
first contact a repairman.this way it will cost you less.
Jul 08, 2008 | Loewe Aconda ACO9303 30" TV
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
