Question about Janome Memory Craft 6300P Professional Sewing & Quilting Machine 66 built-in stitches
Janome 6300 Bobbin is jamming
    Novelist:
  • 268 Answers
Make sure you've got the right bobbin class in the machine and the bobbin case is clean and correctly seated and latched. Make sure the thread is spooling off the bobbin in the correct direction.
Posted on May 22, 2014
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
Janome 712t treadle machine, bobbin jammed
sure take it to the place purchased to be serviced
Aug 16, 2015 | Janome Sewing Machines
Janome memory craft out of sync
check to see if you have the thread in the bobbin case the right way
Oct 13, 2014 | Janome Sewing Machines
How to fix Janome 7700 bobbin jams ?
Check your upper threading, don't touch your bobbin tension, it has nothing to do with thread tangling on the bottom of the cloth.
Jul 16, 2014 | Janome 7700 QCP Sewing and Quilting...
My Janome 6500p is having bobbin issues
here are my suggestions
1. when your sewing check to see if the thread is coming off the thead take up lever,, I've had this to happen to me & it can jam a sewing machine up
2. it's possible that the bobbin case is worn & needs to be replaced
3.also check your top tension
4. try rethreading the machine top thread & bobbin
Feb 06, 2012 | Janome Sewing Machines
Janome 6500 jamming - cleaned out bobbin case - no help
Have you removed the bobbin holder and then put it back in lining up the little red markings on the right hand side? If the case has moved slightly then it will keep jamming and the bobbin thread won't clear to form a stitch. The case is held in place by a magnet and a stopper but it will dislodge if you have a bad thread jam, then it keeps happening even if you have removed all the thread because its not in position.
Check this solution for image how to remove and replace the bobbin case. http://www.fixya.com/support/t9289728-bobbin_seems
When you take out the bobbin case, carefully inspect it for any damage and burrs in the black plastic, if there are any then file them carefully out with a nail file or fine sandpaper, a burr will keep catching thread too. Or you may actually need to replace the bobbin holder if it has been pierced by the needle badly, they are about $35 or so.
You may also want to get it serviced. On my 6500 during its last service the technician added a little piece that is a Janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which is holding the bobbin holder in place better. Haven't had a major jam up since this was fitted so you may want to get this fitted on yours too.
Jul 19, 2011 | Janome Memorycraft 6500P Computerized...
Janome 6500 Memory Craft Prosfessional is my machine. I had it serviced in auckland last year through the Thames Janome shop as the Thames repairer could not fix it. Needed a new shuttle anyway. Anyway my...
You need to ask Janome these questions, rather than Fixya I think. The plastic bobbin in the plastic bobbin holder does make a little bit of noise but I don't find it problematic.
Janome New Zealand Limited reader.gif Unit 5, 325 Ti Rakau Drive, East Tamaki, Auckland, New Zealand
TEL. +64-9-265-0250
FAX. +64-9-265-0251 black.gif E-mail
Web-site black.gif shannon@janome.co.nz
www.janome.co.nz
Providing you are using "Janome" plastic bobbins and are putting them in rotating the right way, as per the little image on the clear cover, there is no reason that the thread cutter should be dislodging the bobbin. When I use the thread cutter, my bobbin turns as thread is drawn off it, but it doesn't move upwards.
Sounds like you have already replaced the black plastic bobbin holder, is that what you mean by "Shuttle"??
My 6500 has had 2 replacement bobbin holders as I keep striking it with the needle during jam ups, which caused plastic burrs on it. On the last service the technician added a little piece that is a janome "after sale replacement" part. It is slightly longer than the standard part, and is a little metal bit on the left hand side of the rotary hook area which seems to be working at holding the bobbin holder in place better. Haven't had a big jam up since he fitted it. But before this, I would dislodge the bobbin holder with a small jam, and then it would just jam and jam until I removed the needle plate with the screwdriver, removed the bobbin and bobbin holder, cleaned out all the thread fragments, then replaced the bobbin holder back into the correct position lining up the two red arrows. Then replaced the needle plate and rethreaded. I learnt to modify my sewing expectations and not try to sew really thick seams as this will just dislodge the bobbin holder again. Jeans hems were always my problem seam, I use a "Seam Jumper" now to handle going from thin to thick seam, and so far, so good.
So I would suggest you ring Janome in Akld and talk to their technical advisor a bit, describing your problem. They may suggest sending it to them for a check out to establish what is going wrong.
If you have trouble describing the issue to then you could always film it with a digital camera and send the file to them.
My only other thought is how you wind the bobbins. It is really important to wind the bobbin smoothly and evenly top and bottom, my 6500 will wind all in the middle if I let it just run, so I always wind carefully and give the thread a nudge with my fingertip to ensure it fills evening top, middle and bottom. But it sounds like you are an experienced sewer and know this already.
I'd say ring Janome and have a chat, I find if you keep your approach friendly and neutral rather than "I've never got on with this machine" that you may get some help from them at resolving this issue.
Jun 27, 2011 | Janome Memorycraft 6500P Computerized...
Bobbin is not filling. It barely turns.
This happened on my Janome 10000...it had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Re Janome 2041
Okay, so there is a jam. Take out the bobbin case and the hook. Remove the bobbin from the bobbin case if you haven't already.
Try and turn balance wheel now. if it is still stuck than you have a pretty big problem. Chances are the timing has been thrown so far that something is bumping something else and keeping it from revolving. Repair probably required.
If you're really lucky and the balance wheel does turn do this:
Clean bobbin case and hook gently with a tooth bush or some such. Make sure the bobbin doesn't have a bit of needle jammed in it. Examine the bobbin case and hook, looking for any damage. There has to be something preventing the normal revolutions of the machine from happening.
Good Luck and if this was helpful please vote for me. Thanks
Mar 02, 2008 | Janome Harmony 2041
Janome Memory Craft 6300P Professional Sewing & Quilting Machine 66 built-in stitches Logo
148 people viewed this question
Top Janome Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Janome Furniture Expert? Answer questions, earn points and help others
