Question about Graco Baby Gear
I placed the rear wheel wrongly, I'm trying to bring out now, to place it properly but can't do it
Spree classic connect
  • Graco Master
  • 1,629 Answers
Hi
We would recommend you contact Graco for assistance
Posted on Nov 18, 2013
How to replace drive belt on a 1993 harley davidson heritage softail classic?
To remove a Softail drive belt FIRST remove the rear wheel then remove the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster as an assembly, then remove the primary chaincase housing, place a support under the rear fork and engine, remove the pivot shaft and spacer, slip the drive belt off from the transmission sprocket.
To replace a Softail drive belt FIRST not that all belts, used or new, must never be formed into a loop smaller than 5.0 in. (130 mm), and must never be bent backwards because this can severely weaken the belt and cause premature failure if it, then install the belt over the transmission sprocket, install the pivot shaft and spacer, remove the support holding the engine and rear fork, install the primary chaincase housing, the primary chain, the clutch, the engine compensating sprocket, and the chain adjuster and the primary chaincase cover, fill primary the primary chaincase with oil, install the rear wheel, align the rear wheel and properly adjust the belt tension to the specified deflection.
Apr 28, 2014 | 2000 Harley Davidson FLSTC Heritage...
My yahoo mail page has changed! All I can see is my inbox messages but no place to send, delete, contacts or anything. What is wrong? I want my classic yahoo mail page back!!!
If you went to a new version of yahoo mail and that is the problem, then to go back to classic mail try lowering your screen resolution to 800 x 600. You may have to log out and then log back in after doing this for it to take affect.
This trick is just to get you back to yahoo classic mail.
It should bring up 2 options for you to choose from, either change back one time only or change back permanently......choose the permanent one.
Hope this helps.
Aug 19, 2011 | Yahoo Mail
The training wheels are not set correctly. When my grandson rides it he falls over. The angle is off. Help!
most raining wheels lock into place when mounted on the rear axle and theres 3 sizes sounds to me you might have the wrong size and make sure you have a stabilizer that connects too the frame.
Apr 14, 2011 | Cycling
I am reinstalling my rear tire on my 2001 roadking..any tips on how to align and balance it .
Unless the tyre is particularly cheap, ballancing has no real effect except to off set the valve.
Align the wheel with two long poles/3" X 2", angle iron, it doesn't matter as long as they are straight. Place them side by side of the rear tyre/wheel. Make sure the front wheel sits in the centre of the gap made by the rear tyre/wheel or adjust the wheel nut until straight.
Ride safe.
Jan 31, 2011 | 2001 Harley Davidson FLHRCI Road King...
Rear turn /parking lights dont work ,turn signals work all other lights work all rear wires have been checked
Check the ground wire.
Place a test wire from the engine case (pick a hidden place to connect.
the wire) to the rear end. Try the base of a light.
Jan 24, 2011 | 2002 Harley Davidson FLSTC - FLSTCI...
How to center back tire of harley davidson 2005 road king
If you have the spacers in the proper places, the rear wheel is where it should be as far as "centering" goes. Not all wheels are designed to be "centered". On a Softail, there is an offset but I'm not positive about your road king.
Now, if you're talking about the alignment of the rear wheel in the swing arm, the RK has the adjusters on the rear of the swing arms's arms. Measure each bolt and when you get the proper belt tension with both bolts being the same length, you're aligned. The way I do it is move the wheel forward until the belt is too loose. Then set the lenghts the same. Then by turning each bolt the same amount each time, I slowly bring the wheel to the rear until I get the correct belt tension.
Good Luck
Steve
Aug 14, 2010 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Rear wheel spacer placement?
Take great care on reassembly ,as the spacers may be of diffrent lenghts which will if put back wrongly will throw the wheel off its true running centre .and cause problems .Allway remember to mark parts or do a drawing when removing and stripping down for repair or servicing ..It saves a great deal of problems .Try and assemble the spacers and look to see if the wheel is in line with the belt drives .
Mar 14, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
Rear scraping sound, Also when placed on lift and in gear (all wheel drive) the rear left wheel does not spin
Take it in for proper diagnosis - that's not supposed to happen in an 'ALL WHEEL DRIVE' - all WHEELS ARE SUPPOSED TO TURN.
May 20, 2009 | 2004 Hyundai Santa Fe
Baby Gear Logo
47 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
