Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Hot tub breaker trips but only when people are in it?
I have a Emerald spa 6 person hot tub. The problem is that the breaker keeps tripping but only when its being used and people are actually in the water. It wont trip by running the pumps, heater, or lights and using them all at once or individually. I thought it was a bad breaker so I replaced the 50 amp GFCI with a 60 amp thinking the breaker was bad. Same problem still exists. If it tripped everytime i tried running or heating it, it seems like an easier problem but I can manually(without being in it) run everything for days without it ever tripping. Any ideas what the problem might be? thanks!
  • Josh Wilson Nov 21, 2013
    Where would I add grounding rods? on the spa side? like out of the controller ground straight to the rod in the ground or on the breaker side? Thanks
    Problem Solver:
  • 8 Answers
This may appear simplistic but could something be shorting out when there are people in the tub ? Have you tried overfilling the tub to see if the breaker trips ? Also you could try isolating the problem by disconnecting electrical items one by one when the problem occurs. Hope this helps.
Posted on Nov 17, 2013
  • 2,113 Answers
Because it is a GFCI. Try making sure that the grounds are all good. Maybe go the extra step of putting in grounding rods into the ground and grounding to the unit. These are just guesses.
3 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: My hot tub keeps tripping the breaker and will
Check for a water leak in the electrical areas of your spa... specifically look closely around the heater terminals, look for wet and corroded connections... If this spa is wired to a plug-in outlet, look at the GFCI plug assembly as well... You can also try disconnecting the blower, pump, heater, etc, from the control pack (one at a time) to determine which item is causing the tripping.
Posted on Apr 14, 2010
john224
  • 1378 Answers
SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Posted on Oct 12, 2010
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Signature Titan II keeps tripping the breaker
check to see if recirculation pump is working if so check to see if heater element is not shorting out
Jul 13, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
An Emerald Spa 1998 keeps tripping the breaker
with power off take cover off control box remove heater element lead make sure to take a picture or a drawing to see where they go back turn on breaker with wires taped up if it doesnt blow breaker you need a new heater element
Jul 10, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
My hot tub keeps tripping the breaker and will only stay on for a short period of time before tripping the breaker. What can I do?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Nov 29, 2008 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
147 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
