Question about Tview D65TSG Dbl din 6.2" w/ navigationbt
Do i need to set my tview d62tsb touch screen to run a amplifier
Please show me how to set this unit to be able to use a amplifier
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
Ok I am having trouble with my Android Craig tablet. There's a message keeps popping up on my screen an it's blocking me from getting to my stuff. The message says "The application Launcher (process...
Phone is getting an error message: "Unfortunately Launcher Has Stopped."
Unfortunately Launcher Has Stopped:
  1. Swipe your finger from top to bottom on the screen to view the notification panel
  2. Touch the Settings or
  3. Touch Apps
  4. Touch Menu or
  5. Touch Reset App Preferences
  6. Touch Reset Apps
  7. Swipe from right to left 2-3 times to show the ALL list.
    (For device running on Android 6.0.X touch Menu then Show system)
  8. Touch Launcher
    (For device running on Android 6.0.X touch Stock Android then Storage)
  9. Touch Clear Data
  10. Touch OK
  11. Power Cycle Phone
  12. Test phone
hope this isn't clear as mud. :) and helps you
Jan 05, 2018 | Craig Electronics Wireless 10" Color...
D65TSG
Hi. From what I'm learning about this unit it seems that the time will stay set until you run GPS. Once you activate GPS it calibrates the unit's time to reflect China's, which I'm assuming is where the D65TSG is made. I haven't seen any solutions to this quirk.
Nov 16, 2012 | Tview Brand New D65TSG 6.2" In-Dash Touch...
I have a Tview screen.there are three formats.AUX CD and Radio.i took my cd out and now the Tview player will NOT accept cds.i have reset it already and it still did nothing.nothing the format for CD will...
Try pressing the reset switch. If there is one, it will be a depression about the size of a pencil tip and will not be marked. If there is no reset switch, try disconnecting power to the unit for a couple of minutes.
Apr 15, 2011 | Car Audio & Video
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
No picture on tview dvd70ts
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Apr 08, 2009 | T-View INDSH DVD PLYR W/TUNR Car Video...
Setting radio stations
if it is touch screen you should be able to tune to the frequency required and then press and hold on position 1-7 or wherever u want the station stored and it should store it i hope this helps
Oct 15, 2008 | Car Audio & Video
Tview D65TSG Dbl din 6.2" w/ navigationbt Logo
44 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
