Question about Sanyo Televison & Video
Servicemenu audio ic is good but still no sound
    Top Expert:
  • Sanyo Master
  • 74,459 Answers
Press [display] key on the remote handset and button on tv set, simoultaniously. "serv" will be displayed on screen to indicate that the tv is now in service mode. To get more details, http://electronicshelponline.blogspot.com/. Service mode entry, adjust and exit procedure to many popular TVs are given in detail.
Posted on Nov 17, 2013
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
Everytime I turn on the television everything works fine except no sound. Sometimes unplugging the set and plugging it back in a few moments later fixes it. Sometimes redoing the 10 minutes long auto...
it signifies that there is a problem in the audio circuit on the PCB BOARD TV, you should check starting from the section "Audio Amplifier" check incoming voice signals on the L or R-in Audio-in Audio that led to the AUDIO IC amplifier. If you hear a sound when touched (touch point of tin solder to use a screwdriver) audio input pin means in part that there is no problem, you proceed to check into the IC close to the tuner (it is usually called Chroma IC / VIDEO + combination of Horizontal Drive + Vertical Drvie + IF). Just look at the physical form of IC is greater than the other ICs. tin solder first check whether there are loose or melting resulting in less good solder connections on each foot of the IC. It enables voice sometimes appear and sometimes not. if, after checked and looked normal / still good, you must replace the IC. I did not explain exactly NO. CODE from the IC because you do not describe the specific model and brand of your Flat TV.
Aug 26, 2010 | Televison & Video
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
No sound from my NAD C325BEE amplifier
audio ic problem or component around audio ic.. good luck
Apr 26, 2010 | NAD C325BEE Amplifier
I can not hear any Audio
the sound IC is bad, that' why you cannot hear any audio from your TV.
You need to change the sound IC to hear audio from your TV again.
Good luck
Mar 05, 2010 | Haier HTF24R21 24" TV
Unit has sound, no vertical deflection. caps and output ic ok. have b+ to output. nothing at pin 2 of output ic.
If there's an audio,,it might be the defective Vertical IC...but check first if there's 24v-26vdc supply coming from FBT going to Vcc of Vertical IC.
If there's no Audio,and only white horizontal line in the screen,check the Vertical out of Jungle IC.
Oct 12, 2009 | Toshiba 27D46 27" TV
Sound problem
good evening ! the problem of your phone is buzzer and speaker ,or the audio driver ic try to chagne that ! good luck !..god bless....
Sep 06, 2008 | Nokia 6600
Audio
sounds like a failing audio IC, or capacitor in the audio circuit, probably an IC or bad connection @ the IC. technical schematic or the shop if one is not familiar with component repair!!
good luck stereo tech
Dec 03, 2007 | Toshiba 43H70 43" Rear Projection...
Sound
its still fixable. change the audio output ic(integrated circuit). but if you are not inclined with this job, have it check with a qualified service technician. good luck!
Jan 31, 2007 | Sylvania 6319CE 19 in. TV/VCR Combo
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
