Question about NEC AP00-B Pn-AP00-B Smdr/Mci Integration Card P/N: AP00-B - O
Setting pabx I use Cross Cable with RS RVS 4 CA-A, the modul PN AP00 B blink but my PC didn't receive anything
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
The cross cable has a fault with in it
Posted on Dec 04, 2013
Where is the remote start fuse located?
Do your power door locks work ? There is no fuse for just the remote start !
Remote vehicle start (RVS) begins as an RF message received by the remote control door lock receiver (RCDLR) from a keyless entry transmitter. The RVS request is sent by the RCDLR to the body control module (BCM) via serial data. The BCM monitors system conditions such as content theft deterrent (CTD), hood ajar status, and body DTCs to determine if an RVS even will occur. If conditions are determined to be acceptable, the RVS message is sent to the engine control module (ECM). The ECM monitors system conditions such as engine control parameters and vehicle theft deterrent (VTD) to determine if engine starting will be allowed. If conditions are acceptable, the ECM will initiate engine starting. During the engine run time in a RVS attempt, before the operator enters the vehicle, the ECM may discontinue engine operation if system conditions require it or a message is received from the BCM requesting the engine be turned OFF.
The RVS system will not operate if any of the following conditions are present:
A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
The vehicle is in valet mode.
More than 2 remote starts have been attempted.
The hazard switch is in the ON position.
A current hazard switch DTC is set.
The vehicle hood is ajar.
A current hood ajar DTC is set.
The CTD system detects an alarm trigger.
Excessive engine RPM
Excessive coolant temperature
Accelerator pedal position greater than 0 percent
Vehicle not in Park
Vehicle theft deterrent malfunction
A current automatic transmission shift lock control system DRC is set.
A vehicle speed sensor signal is detected by the ECM.
Sep 13, 2015 | 2007 Pontiac G5 Gt Coupe
MF Digital Scribe 9000 with Picojet disc printer. Hello, could anyone please help with the pin configuration connections of the 9 pin seriel cable to mini din control cable connection from the duplicator...
Have you tried emailing tech support?
http://www.mfdigital.com/techsupport.html
Failing that, and lack of pinout, serial communications can be done with only 4 connections, Transmit and Receive (TX, RX) ground (GND) if you do it with no handshaking. You'll need Data Terminal Ready (DTR) and Data Set Ready (DSR) and or CTS/RTS (Clear/Ready to end). You may have to trial and error it.
Pin 1 - Carrier Detect (CD) - only needed for a modem
Pin 2 - Receive Data (RX) - Cross over with TX
Pin 3 - Transmit Data (TX) - Cross over with RX
Pin 4 - Data Terminal Ready - Cross over with DSR
Pin 5 - Signal Ground (GND) - Goes to other side ground.
Pin 6 - Data Set Ready (DSR) - Cross over with DTR
Pin 7 - Request To Send (RTS) - Cross over with CTS
Pin 8 - Clear To Send (CTS) - Cross over with RTS
Pin 9 - Ring Indicator - Only needed for modem
May 20, 2014 | Computers & Internet
How do I get an owner's manual? I tried on your website, but didn't get the right manual. I need pn - 300.
Use this link: http://www.cellphones.ca/cell-phones/pantech-pn-300/
On the right side of the page, you can download the manual. Hope that helps! Please rate my solution!
- Frankie
May 06, 2011 | Pantech Cell Phones
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Jandy Aqualink display reads "waiting"
System locked up. Handheld is frozen at WAITING screen means Microprocessor is locked.
Here is what you do:
1. Turn off power to the system (control box)
2. Disconnect battery at the Power Center (9volt battery in control box/cross tip screwdriver required)
3. Turn on power
4. Reconnect the battery
5. Reset time and date on PDA.
6. Thank me.... BadWally sends
Aug 20, 2009 | Jandy AQUALINK RS TELELINK KIT
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Jan 04, 2008 | Ricoh FAX5000L Plain Paper Laser
NEC AP00-B Pn-AP00-B Smdr/Mci Integration Card P/N: AP00-B - O Logo
49 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
