T.V. has no picture
Yesterday tv turned on normally,mid-morning I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. Is it fixable or dumpable?? Please HELP!!!!
  • racer_ron Oct 28, 2008
    My Sept. 2006 Orion TV Model TVD2710 has the same problem. The posted solution says to "fix vertical controls". But, how do I do that? Specifically. I'm not an electonics wizard. Are there any repair locations in the Kansas City, MO metro area?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Posted on Oct 07, 2007
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
BLACK SCREEN WITH A BRIGHT HORIZONAL 1/4 INCH
HELLO
This is called Field Collapse and usually caused by the frame/field output going open circuit and/or the componants that surround that part.
Call a service centre in your locality who put it right (:-)
Nov 22, 2009 | Sylvania Televison & Video
Toshiba projection TV. Bulbs wont come on
The deflection board in failing, eventually it will not come on at all, disconnecting power is only reseting the HV shutdown protection circuit which is the reason your set if failing. Have a technician replace the Horizonal Output Transistor and the flyback transformer.
Please comment if you need futher assitance.
Delhielectronics@live.com
Sep 29, 2009 | Toshiba 55H70 55" Rear Projection...
Dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 10, 2009 | Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Picture tube problem
This problem indicates a defective vertical IC or dry solder joints on the IC connections.
Jan 27, 2008 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
TV goes black at bottom and has horizonal lines in middle?
Hello, please check the high current area around flyback transformer, horizontal output transistor as well as the deflection connector for bad soldering. Best regards, Arpi If you need more info please advice.
Apr 12, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
