Question about Home
Hi, we have a toilet installed with a viva flexible pipe. Each time toilet is flushed the flexible pipe loosens itself from joining to permanent pipe causing a small water leak. How can we stop this? Thank you
  • 2,113 Answers
I fixed a few like that recently. I just replaced the ballcock with a fluidmaster, $12 or so and the kit comes with a better way to hold the hose in place.
Posted on Nov 29, 2013
  • 171 Answers
SOURCE: toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
whytfang
  • 170 Answers
SOURCE: Water comes from bottom of tank when commode is
Ok the toilets work is that the tank reservoir is where your fresh water....is stored....and the flush valve...(if you take the tank lid off you will see that the handle is either connected to a chain or uses a lever to lift something called a flapper....it is usually black but it can be gray..or blue...also there is a flash valve that is a long tube and a round bottom with a rubber gasket...that seals the flush water into the tank...reventing it from entering the bowl.......when you lift the handle water dumps from the tank...into a s-shape tunnel called a trap...(this is in place to prevent sewer gases from entering the house the water sits in the bottom of the trap acting as a seal against smells...gas...etc...from the sewer line....Now your tank is mounted to the bowl by (2 or 3) bolts that you can see and access from inside the tank...however the person doing this will have to also reach under the toilet where the tank mounts to the bowl and hold a pair of pliers or a crescent wrench on the nuts which hold the tank in place.....after these are removed...the tank will lift off of the bowl.(now obviously the water has to be shut off and be disconnected from the tank....when the tank is lifted ...a small amount of water may spill out ...but it is clean water...so no worries....since the tank and the bowl are made of porcelain they obviously would not seal just sitting on top of each other so the tank...has the bottom part of the flush assembly which is mounted to the tank by way of a large plastic nut extends out of the bottom opf the tank 2-3 inches......around this is another black or gray about 3-5 inches in diameter...and costs less than $5 at Home Depot.....change this out, reassemble and your back in business. Be advised that the flapper in the bottom of the tank...if you ever have to change it out and the tank gasket you are going to change out (after a long period of use or just time and deterioration)...leave black residue on your hands...if you handle them...but it is safe and easily washed off...it just may freak.. a layperson out....so one may want to use some gloves they can toss afterwards....Any other questions....and I can absolutely answer them in regards to toilets...as i have repaired and or replaced 2500 - 3000 in my 35 years in the apt/home maintenance industry.
I hope this helps.....thank you for rating my effort...and good luck....tha Fang.
Posted on Mar 29, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
  • 39 Answers
SOURCE: Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Posted on Aug 05, 2009
  • 129 Answers
SOURCE: Hi,
install a fluidmaster flush valve.
Posted on Sep 26, 2009
There are 2 bathrooms and flushing one toilet makes the other toilet start to bubble one bubble up
good chance that it is a blockage or the pipe vent is blocked
get in a plumber with a "snake" ( a flexible cable tool that goes down the pipes to cut and remove blockages )
Oct 13, 2017 | Home
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
How do i flush the pipes out? (when i flush the toilet it will not re-fill water) one of the answers was to flush the pipes
If you have a supply shut off to fixture shut it off and disconnect supply line from inlet to toilet . If your supply line to toilet is a flexible line then bend it so that you can direct water to small container. Slowly turn valve on to see what flow rate is at that point. If flow rate is not good then I would shut water off to house and replace valve. If flow rate to toliet is good I would reccomend you replace flush vallve. To do this shut off water supply to toilet. Disconnect supply nut to bottom of flush valve. There will be a retaining nut that holds flush valve in place in toilet tank. Remove flush valve after removing fill tube from flush valve to overflow tube. Replace with toto replacement valve or use Fluidmaster 400A. Instructions on box of 400A are easy to follow and if you have flex connector you won't need supply line washer. I would reccomend that before you install new valve that you put rubber gasket on shank of valve and slid it about halfway up the shaft. Make sure that inside of tank is dry and use a small bead of silicon caulking on top and bottom side of shaft gasket. slid gasket the rest of the way on valve shank,install in tank and put on retaing nut hand tight. Push down on top of valve and using channel lock pliers finish tightening nut securely.You may need to reach into tank and grasp valve body to stop it from turning. There are other things you can do if you have a working supply valve. Shut off valve and remove screws that hold top of valve in place and remove and clean surfaces. You can turn valve on slowly to help flush out any rust or mineral deposits. I hope this is of some help to you. Thanks
Nov 21, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
The toilet cistern is filling up but the toilet pan is not getting enough water presure to empty
check that the water in the cistern is up to the mark etched on the inside
Do you have a close couple or a washdown [with pipe from cistern to pan]
Mar 04, 2010 | Home
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
Toilet pan installation procedure
Hi muller2012,
Thank you,
Oct 14, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet tank often refills by itself
Hi jj4help
You're looking for a solution to fix a toilet that flushes by itself at regular intervals.
No sweat. Sending me a picture was a great idea. I can see that you have a very common setup in your tank. Although there is no "permanent" solution, it is very inexpensive to fix every few years! Just buy a "flapper" anywhere. There are different colors to choose from, which reflects the different materials they are made from. Personally, I find the red ones tend to have the longest life span.
Proceed by carefully cutting off the center ring. Don't cut off the eyelets! The center ring would be used in a different toilet (this is where the picture really helps). Now the flapper will match the configuration of the old one.
Simply turn off the water, flush, remove the old and install the new. Take note of the chain length. Set the new one the same by simply moveing the clip down to another link, let the extra chain hang. While you're at it, replaceing the handle at this time might be a good idea. It looks pretty old. If you do, remember that the hold down nut on the handle has reversed threads. That means it loosens clockwise (standard would be counterclockwise to loosen).
Please give me a rating here at fixya.com before you sign off
Thank you,
Sep 10, 2008 | Home
Home Logo
81 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
