Question about Gaggia Classic Espresso Machine
I have a gaggia nera 2 group on 3 phase is it possible to connect it as a single fase? In any way ? Thanks all
2 Suggested Answers
SOURCE: Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Posted on Mar 22, 2009
Can i get a 200v invertor to run a 3-phase sewing machine at home
You will have to check with an electrical whole shop (business) but I doubt it as there are 3 different phases in three phase each one needing its own inverter
It would possibly be cheaper to get a single phase motor to replace the 3 phase unit or enquire from your power utility , the possibility of having 3 phase connected to the premises.
Jun 16, 2015 | Sewing Machines
I have a Faema E91 3 group. I need to change it from 3 phase to single phase. any advise you can give
No, you will not have to change the elements, though the connexion cable will have to be approximately twice as thick. The three phases will, of course, deliver their power alternately, and the thinner neutral cable takes account of that. Do seek professional advice before connecting it to the mains supply.
Mar 21, 2015 | Faema Coffee Makers & Espresso Machines
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
I switched on my Rancilio 2 group E/S model without the water supply. Will be there any problem with this. I thought I heard a noise and M confussed and worried that my machine might have been damaged!!...
If it is a 110 machine it is most likely single phase, most equipment in the US(assuming you are in the US is wired single phase). If you turned it off seconds after you realized it was not connected to water you will be fine, there would be no damage to the pump. Just connect the water then turn on the first switch only when the boiler fills tunr on the middle switch.
Aug 17, 2011 | Rancilio Epoca ST-1 Espresso Machine
Where can i find ac motor connection diagrams, specifically, single phase forward and reverse, and 415v motor to 240v power diagrams? thanks andy
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Jun 15, 2011 | Air Tools & Compressors
How do I switch the wiring for a Garland Model S 686 -2 Stove from Single Phase to 3 Phase?
If the oven is a three phase oven currently wired on single phase there will be three active terminals at the terminal block. There will be links or bridges which connect the single phase to each of these active terminals. Remove these links and connect each phase to each terminal.
Feb 24, 2011 | Garland S686 Electric Kitchen Range
How many VoltAmps does the LG LS-K1830CL consume?, What is the voltage?, Mono or 3 fase?...
BTUs: 18,000 (C)
SEER: 10
Interior Voltage: 36
Voltage: 208/230 VAC
Maximum 8.5 amps
Single phase.
Is it helpful?
Dec 28, 2010 | LG LS-K1830CL Cool Mini Split Air...
How can i get single phase power from my 3 phase generator
I have not wire this myself
Wiki says under heading of single-phase:
http://en.wikipedia.org/wiki/Three-phase_electric_power
Single-phase loads may be connected to a three-phase system in two ways. A load may be connected across two of the three phase conductors or a load can be connected from a live phase conductor to the system neutral. Single-phase loads should be distributed evenly between the phases of the three-phase system for efficient use of the supply transformer and supply conductors. Where the line-to-neutral voltage is a standard utilization voltage (for example in a 230 V/400 V system), individual single-phase utility customers or loads may each be connected to a different phase of the supply. Where the line-to-neutral voltage is not a common utilization voltage, for example in a 347/600 V system, single-phase loads must be supplied by individual step-down transformers.
So it sounds like you take 2 legs of the 3-phase.
or
Take one leg of the 3-phase and connect to neutral ... neutral could be a ground rod.
I would put a meter on that circuit before hooking up my power saw.
Nov 17, 2010 | Electrical Supplies
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
Is posible run a single phase electric motor from a source three phase 120/208 wye connection the motor is rated 230 volts AC
It is indeed possible to use ONE Phase to run a motor, You simply use One Phase and Neutral. BUT ONLY if the 3 phase is Double, more or less, the required usage Voltage, EG: 440 3 phase, will be OK, for 220 single phase, . But 220 3 Phase,will not run a 240. single Phase. So in your case is suspect not, it really will do no harm to try though. it just wouldn't work, if not enough "juice", be careful.
Feb 24, 2010 | Heating & Cooling
Gaggia Classic Espresso Machine Logo
26 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
