Question about Sewing Machines
Www simplicityhomecare com
Where can I get an manual for a simplicity easy lock sl804 serger?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sewing Machines Master
  • 102,366 Answers
Sorry, I don't see any free ones available, but you may order one from http://www.sewingpartsonline.com/instruction-manual-simplicity-sl804.aspx
Posted on Nov 17, 2013
dupina
  • 110 Answers
SOURCE: mine is a simplicity 804 easy lock
Your knives may be blunt and need sharpening or replacement.
Check also if the knives are aligned properly. Remove the material and turn the handwheel slowly. The knives should pass each over like a pair of scissors and there should not be any cap between the blades.
If everything seems to be okay and it still does noet cut tne material, replacement is the only option.
Posted on Dec 08, 2007
SOURCE: Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Posted on Mar 29, 2008
SOURCE: Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
Posted on Nov 11, 2009
  • 1116 Answers
SOURCE: Where can I find a manual for a Simplicity Easy Lock 804 Serger?
http://www.simplicitysewing.com/manuals/
Posted on May 02, 2010
Tally Girl
  • 1129 Answers
SOURCE: I need a manual for a Simplicity Easy Lock Serger
You can purchase a manual for this machine from the following link for $US14.99
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
I can't see it anywhere for free download unfortunately. But you may find that looking at a manual for another 4 thread overlocker may get you started. If you try this link http://www.singerco.com/accessories/instruction-manuals you can look at the free Singer downloads,
try this link for their 654 3/4 thread model http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf
it may give you some help now.
Essentially, to change the stitch width you can either move the lower fixed blade wider to cut less fabric or tighten up the upper and lower looper threads in order to close up the stitching.
Moving the blade usually means opening up the front cover door, putting pressure on the upper blade and swinging it up out of the way. Then you can adjust the lower blade, usally by turning a knob near to it. Sometimes this knob will be marked 1, 2, 3.
Adjusting the looper tensions is done by changing the tension dial settings for the thread needing adjusting. If its a standard four thread overlocker that produces a "marrow" seam it will have two needles and two loopers, upper and lower. Generally on most overlockers, the upper looper will be the second from right tension dial and lower looper will be right most tension dial - turn up one half number to tighten, or down one half number increment to loosen, then test stitch again. The needles shouldn't need adjusting too often.
I usually start with all tension dials on 5, test stitch, then adjust from there. Some fabrics will tunnel (pull in) if the seam is too wide so you need to either move the blade to the left and trim more fabric or loosen off the loopers. Or in the reverse, like you are getting, the threads will hang off the edge.
There is some good serger information on Debbis Cosgrove's pages www.sewing.about.com but if you have never used a serger, then getting the genuine manual is probably best.
Posted on Oct 17, 2011
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
Recently I found this manual for Simplicity Easy Lock 804 on eBay...
May 02, 2010 | Baby Lock Eclipse Serger
Oct 03, 2009 | Simplicity Serge Pro SW432 Mechanical...
I need help with the tention settings on my simplicity serger pro please
All the problem that everyone had with the Simplicity Serge Pro are able to be fixed with the manual. I downloaded the manual from the Simplicity Home page: www.simplicityhomecare.com. That simple. Thank you for your assistance because you made me realize that I had to go get the answer myself if I wanted to get anything done yesterday. Waiting for 24 hours was just too long for me. There is also an 800-822-6691 hotline as well. I have already finished my project. Have a great day!
Nov 03, 2008 | Simplicity Serge Pro SW432 Mechanical...
HELP!
Hi, I have a Simplicity easy lock 804D serger and I have the owner's manual, and I'm able to give you a copy if you don't have one, I need the foot control, and I don't know how to take one.
my e-mail is ana_agui@hotmail.com, I leave in Florida, in fort myers.
God Bless you.
Jan 04, 2008 | Brother 925D Serger
Bobbin?`
Tania,
I'm trying to find a manual for a Simplicity SW2145. If you have any suggestions I greatly appreciate some help.
Thank You,
J. Eise
Oct 21, 2007 | Simplicity Fashion Pro SW2145 Mechanical...
Sewing Machines Logo
94 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
