How do i hook up dvd player or wii to samsung tv and not get black and white picture?
Both wii and DVD player shows n black and white
    Problem Solver:
  • 12 Answers
First do you have to wiggle the connection to get them to work? Cables new? Inputs on back of tv tight don't feel like they are falling off? Also the cable where it goes into the system needs to be tight and shouldn't have to twist or bend it in a way to get it to work if so will need new cables. Make sure red to red wht to wht Ylw to ylw How do i hook up dvd player or wii to samsung tv a - 11_17_2013_5_40_59_pm.png
Posted on Nov 17, 2013
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: teac usb2 tv tuner
Try this they have some great info. http://www.techlore.com/article/10257/ Good luck
Posted on Jul 21, 2006
techman
  • 3130 Answers
Try this and good luck http://www.techlore.com/article/10257/
swoop611
  • 488 Answers
SOURCE: Black and white and no sound!
You are trying to copy or record a copy protected video or your VCR has internal copy prevention turned on. If you wish to copy tapes or dvd's, use a PC based system. You can also pull the raw video information off the VCR if you know where to connect to on the video board of the VCR. I cannot tell you how to to this as I have no idea which VCR you are using however, google the brand and model of your VCR, find a schematic and you should be able to pick the raw video feed into the video decoder chip and use that. Use shielded cables and NEVER undertake any work inside anything when it is plugged into the power outlet, disconnect it first by removing the plug from the outlet (never rely on the switch either).
Posted on Dec 12, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
DVD player now showing in black and white
Make sure your av channel is av2 and not av2s as this will give b/w playback
Sep 13, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Apr 05, 2009 | Samsung Televison & Video
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Dvd showing in black and white
I'm assuming you're using the yellow ended video cable and two audio cables hooked up to your TV to display the signal. If so, I would just make sure they are connected in the correct output jacks on your dvd player and that they match up with the input jacks on your TV. If so, then I'd try another DVD player to see if that one plays OK.
Jan 13, 2007 | Samsung DVD-P230 DVD Player
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
