Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Hoover Nextra washing machine - water bac...
By smileyone on Oct 07, 2007
When starting wash programme, detergent washed down but then water comes flooding out of the detergent drawer! I stopped programme, mopped up and seems that water level out of detergent drawer not dropping.
Advice please as looks as though there is either a blockage into drum or maybe there is a valve stuck? - so is there an easy way to release/rectify?
Many thanks!
Comments:
Oct 08, 2007
- Thanks, I've pulled out and cleaned drawer but I can see that water level for where water (and detergent) is fed into machine hasn't dropped so problem looks to be further down
Oct 11, 2007
- Hi, in the end repairman came out and apparently it is a common design fault with Hoover Nextra machines to have a u bend on the black rubber pipe that feeds down from the detergent drawer into the machine.  Watching what he did, the repairman folded back the rubber drum seal to access the rubber pipe which was clearly blocked with soggy soap powder so he scraped it all out and refitted pipe.  No requirement to access machine from rear or to access the water level tube.  Tip appears to be to use tablets in wash rather than detergent!
Same Problem
Nov 26, 2008
-   I have a Hoover Nextra 7 and when I put the machine on it fills up with water but a few seconds into the filling process some water comes out of the dispencer draw and sometimes when ever I select a programe sometimes it will start a differant programe! its so anoying-   Guest
Solution #1
posted on Oct 08, 2007
Somewhat Helpful)
premm
Rank: Guru
Rating: 93%, 3320 votes
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Comments:
Oct 10, 2007
- If this is a front loader, do open up the rear, after disconnecting from the wall socket.  There is a thin tube going down from the control panel to the water exit area; disconnect this tube from the top and blow into it, air should freely flow; if not, clear this tube. Refit.  This is the water level tube, it should be clear, your machine would then not flood.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
elite oasis is that a quaitly machine
Answer
What is the most reliable top loader washer to buy?
Answer
how do i replace the brushes on a Hotpoint Aquarius Extra Power Stream?
Answer
dryer does not heat no instructions first time trying dryer cant get heat am i doing something wrong
Answer
hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
