Question about Car Audio & Video
Hifonics brutus bxi proHifonics Brutus BXi 1206D amp got it from a friend it turns on but when i connect my speakers its making a crackling sound when the amp is down i test my speakers and its working fine it almost sounds like something is blown
    Problem Solver:
  • 18 Answers
YOU WILL NEED TO TAKE IT TO A PROFESSIONAL REPAIR PERSON. SOUNDS LIKE A TRANSISTOR IS CRACKED AND READY TO BLOW.
Posted on Nov 20, 2013
2 Suggested Answers
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
I have a brutus bxi 1206d 1200 watts, and the amp is coming on fine not protected. But there is no sound output. u can hear a small feedback rumble when connecting the input rca's. But thats it. My...
i would check the speaker cables to see if something came disconnected first maybe wire i touching other terminal shorted out the channels output .
run a new set of rca cable to see if one use are bad . check to see if rca cables pluged into right output of radio . check to see if your remote wire is powering up the amp to turn on the amp ..
will still light up with battery power but will never put output to the speakers with out the remote turn from the radio ... how to check this is to disconnect the cable at the amp and take a short 18 gauge wire and strip both ends and touch the battery terminal at the amp terminal one end the other end where the remote wire is mounted on the amp if do this for a few seconds to see what happens or better yet buy a digital volt meter and check for 12volt a the remote wire when you turn on your radio
Dec 23, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics brutus 2000 watt help??!!??
If an RCA took a dive your amp has most likely seen a very nasty input spike and may never be the same as its circuitry has been damaged.....sorry
Mar 09, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Brutus 1206D
set the lp filter to about 100 to 125 (or lower if want seep boomy only) , put the bass eq no more than 75% but i would recommend no more than 50%, gain is to match the sound not to adjust power with so it is a user preference start all the way down and slowly go up till u hear distortion then turn it back down by about 10 - 15 %, phase shoild typically be at 0 degrees, subsonic depends on if you r using sealed or ported ported turn it all the way down then adjust as needed to get rid of the lower sounds you dont want (muddy sloppy sounding bass) if sealed turn it all the way up to at least 35 hz.
Jun 18, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Brutus 1206D
u need at least another amp and set em at 2 ohm and then just take it to a shop aand ask thee guy to equalize it he shouldnt charge u or at least 10 bucks
Brutus 1206D
yes it can only at 2 ohms never 1 ohm good luck
May 25, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
No sound in my Hifonics Brutus BXi 1206D amp
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
