Question about GE Microwave Ovens
Microwave runs as if all is well but will not heat
Hello All, I have GE Cafe Microwave: Model: cvm2072sm2ss Serial #: HS900262B Installed June 2009 This morning I went to heat up my coffee. I set it for 30 seconds and hit the start button. The microwave started and then the inside light started flickering and the turn table had some hesitation as it turned. The 30 seconds ended and my coffee was ice cold. I tried again, and this time the microwave ran as if all was well. No flickering, no hesitating, vent opened up just fine. My coffee was still ice cold. So in summary, it is running beautifully, but is not heating anything up. Any help would be greatly appreciated.
    New Friend:
    Problem Solver:
  • 5 Answers
How old are u
Posted on Nov 17, 2013
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
freetek
  • 5568 Answers
SOURCE: GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Posted on Aug 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
I have a ge cafe microwave...the cook and defrost functions do not heat up but the melt function still works?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 07, 2011 | GE Microwave Ovens
GE Spacemaker XL1800 Microwave No Heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
yuetywe
Jul 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
I bought a ge microwave model jes735 in june from sams club. the middle of august it quit heating and i would like to know where to get it fixed. i can't find the receipt but i sent all of the...
You can contact GE Customer Service here.
If you registered your warranty, that makes things smoother.
If not, no problem, they'll go by the model, serial and date code and refer you to the nearest local servicer.
Aug 24, 2008 | GE Microwave Ovens
Microwave Ovens Logo
208 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
