Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
43 error fisher paykel - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • 37 Answers
Out of Balance Switch Fault Fault code #43
The out of balance switch is permanently activated or the harness to it is disconnected.
Posted on Nov 18, 2013
4 Suggested Answers
  • 28 Answers
SOURCE: fisher and paykel intuitive washer what is a code 43 please
code for out of balance oob switch probably needs replacing if load wasn't off to one side.
Posted on Jun 21, 2008
SOURCE: Fisher and Paykel Intuitive has
I had the same problem, code 43 is an out of balance switch problem, i found mine was just sticky, if you pull it out (under the electronic control unit, under the top panel) you may be able to find out if its stuck or if it needs a new one, you could possibly find one from another model. hope this helps
Posted on Dec 26, 2008
I had a faut 43 showing on machine. I took the advice and removed the out of balance sensor which has the white and yellow wires attached. I did not pay attention which wire goes where, silly me, Can anyone advise which wire goes where, connectors on side and end of switch
Posted on Jun 28, 2009
Fisher & paykel refrigerator RF195A
Hello!
Error F20 - it often means that the light bulb of the refrigerating chamber burned down. You need to replace it.
Here is also a link to the manual.
http://manualsbrain.com/en/manuals/1295058/?page=43
Hopefully, it will help you!
May 16, 2017 | Fisher Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Error code 43 on intuitive top loader
hello click this link for error code 43 this is an out of balace error and this link will tell how to fix as well http://applianceguru.com/forum2/3397.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 43
Hi just read your posting.Error code 43 is called OUT OF BALANCE SWITCH ERROR.This means either your switch is faulty or your your control module is faulty.95 % of the time it is your switch which is located under the control module which is under the top panel.If you want I can guide you step by step in the replacement of this switch.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Sep 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine stopped filling up and an error 43 or 43 came up on screen
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Intuitive has Error Code 43
Aug 20, 2008 | Fisher and Paykel Washing Machines
Fisher and paykel intuitive washer what is a code 43 please
Jun 20, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
211 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
