Question about Blendtec Ktec Icb4 Smoother Commercial Mixer Blender W/ Sound Enclosure
Spark coming from inside of motor
Every time want to blend on my blender what's is it motor or the magnets
  • Julio
    Julio Nov 19, 2013
    Could buy replacement motor for blend tec smoother 15
    From third party company instead from dealer
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Waring blender shoots food out the top
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Oct 22, 2011 | Waring 6000CG 60th Anniversary Blender
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Was blending this morning and all the sudden the blade stopped spinning. all of the lights work, and I've tried putting it on "pulse" mode, but nothing can get it spinning again. any ideas?
Pretty much that is what happened to me. I found that the motor has 2 "thermal cut-offs" (SEFUSE 113oC). If the motor heats up even a little, these babies kill your blender. They are thermal fuses. Once they blow, it is over until they are replaced. To fix this, the motor must be removed. The spline gismo on top of the blender unscrews with reversed threads. I suggest unsoldering the lead wires from the power supply board, and replacing when done. The cut-offs are inside the taped on white cloth insulation on the top of the field magnets near the brush assemblies on both sides. I replaced them (both were blown) with 2 of NTE8242 ($1.60 each, 240oC 15A). These are way too hot, but that is what I had on hand. I thought that the electronics were defective at first, and I replaced the entire board assembly with a small/cheap ceiling fan wall switch /speed controller from the hardware store (600W 5A) for $10. The root cause of all of this is that the motor fan is not working. The airflow is blocked by base. I put small extenders on the feet and now there is much more airflow. Only time will tell if this is an effective fix. etc. It really makes me wonder how it got past UL approval.
Jul 26, 2010 | Cuisinart BFP-10 7-Speed Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Westinghouse inteliblender
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a warranty...it might just be easier to buy a new blender.
Sep 27, 2008 | Westinghouse 0101 IntelliBLEND¿ Work...
Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Jul 10, 2008 | Blenders
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blendtec Ktec Icb4 Smoother Commercial Mixer Blender W/ Sound Enclosure Logo
35 people viewed this question
Top Blendtec Blenders Experts
eyecam
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
