Question about Health & Beauty
The stem on the bottom of the medicine cup broke. I have a probasics by pmi nebulizer. Where do I purchase parts?
  • 136 Answers
Go to your doctors office. I'm sure they will give you another mask circuit that has a new cup
Posted on Feb 01, 2014
5 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: probasic riteneb
If it looks like fog coming from the mask it is doing it's job,If not,the filter may need changing.(A little water goes a long way in those machines)
Posted on Jan 07, 2009
r321567499
  • 74 Answers
SOURCE: Parts on the Pink car Nebulizer
The funnel is called a "diffuser". It just sets inside the measuring cup and will gently vibrate during a treatment to ensure all the medication runs off the sides the cup to be atomized. You can also ask your family Dr. to review the set up with you if you are concerned that you are not using it right.
  • 31 Answers
SOURCE: no medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
Posted on Jun 26, 2010
SOURCE: Think I'm missing a part in the nebulizer cup.
Pulmicort respule must be used with a jet nebulizer to aeorlize. It cannot be used with an ultrasonic nebulizer
Posted on Sep 30, 2010
My nebulizer is not pushing the medicine out. Its loud when the green tube is not connected but once its connected it gets real low and pushing nothing out. can you help me
Hi brownsugar80
Two things,
1. Sounds like your machine is and older one.
first check to see if you have all your parts to the circuit (the cup you put your medication in. It won't dispense the med if you are missing the little mushroom looking thing inside. If your are not sure, replace the whole circuit .
2. If that doesn't cure the psi then you have an internal problem. Take to a tech to repair the o rings or broken connection inside the neb.
Good Luck
Tim
Apr 30, 2011 | Probasics Health & Beauty
My nebulizer is not making fumes
Try this. Begin by disconnecting each end of the tube from the bottom of the nebulizer running water through it. This will help dislodge andy blockages.
Turn the top of the cup and lift it off. This will expose the cup baffle. Take the baffle and the cone out of the cup. Rinse it with warm water and dish soap to remove clogged medicne.
Wash out the cup by soaking it in warm, soapy water. Rince out the cup until all of the soap is gone, and make sure water is flowing through the cup openings.
Reattach the hose to the output port on the nebulizer and make sure you have a good connection. Put the loose end of the hose onto the bottom of the cup and reassemble. Make sure you put your medicine in before you reassemble the cover.
If this doesn't work, make sure you have power running to the device. Check all of your connects and try a different outlet.
Mar 01, 2011 | Computers & Internet
Nothing comes out
You should either clean the medicine cup and tubing with 1 part vinegar and 2 parts water and let it air dry (shouldn't use dishwasher to clean it), or replace the kit and the filter (do that anyway) and it should work fine after that.
Jan 24, 2011 | Respironics Inspiration Elite Compressor...
No medicine coming out of nebulizer
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Probasic riteneb
Jan 07, 2009 | Probasics Rite-Neb Mini Compressor...
Dec 31, 2008 | Drive Medical Checker Nebulizer Yellow - 1...
Health & Beauty Logo
127 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
