Question about Health & Beauty
I have a probasics nebulizer machine and the stem on the bottom of the medicine cup broke. Where do I purchase a new cup from?
Contact Probasics for information regarding replacement.
or visit Bronchitis Symptoms And Treatment for more information.
Posted on Jul 09, 2014
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: probasic riteneb
If it looks like fog coming from the mask it is doing it's job,If not,the filter may need changing.(A little water goes a long way in those machines)
Posted on Jan 07, 2009
r321567499
  • 74 Answers
SOURCE: Parts on the Pink car Nebulizer
The funnel is called a "diffuser". It just sets inside the measuring cup and will gently vibrate during a treatment to ensure all the medication runs off the sides the cup to be atomized. You can also ask your family Dr. to review the set up with you if you are concerned that you are not using it right.
  • 31 Answers
SOURCE: no medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
Posted on Jun 26, 2010
The stem on the bottom of the medicine cup broke. I have a probasics by pmi nebulizer. Where do I purchase parts?
Go to your doctors office. I'm sure they will give you another mask circuit that has a new cup
Nov 17, 2013 | Health & Beauty
My nebulizer is not pushing the medicine out. Its loud when the green tube is not connected but once its connected it gets real low and pushing nothing out. can you help me
Hi brownsugar80
Two things,
1. Sounds like your machine is and older one.
first check to see if you have all your parts to the circuit (the cup you put your medication in. It won't dispense the med if you are missing the little mushroom looking thing inside. If your are not sure, replace the whole circuit .
2. If that doesn't cure the psi then you have an internal problem. Take to a tech to repair the o rings or broken connection inside the neb.
Good Luck
Tim
Apr 30, 2011 | Probasics Health & Beauty
My nebulizer is not making fumes
Try this. Begin by disconnecting each end of the tube from the bottom of the nebulizer running water through it. This will help dislodge andy blockages.
Turn the top of the cup and lift it off. This will expose the cup baffle. Take the baffle and the cone out of the cup. Rinse it with warm water and dish soap to remove clogged medicne.
Wash out the cup by soaking it in warm, soapy water. Rince out the cup until all of the soap is gone, and make sure water is flowing through the cup openings.
Reattach the hose to the output port on the nebulizer and make sure you have a good connection. Put the loose end of the hose onto the bottom of the cup and reassemble. Make sure you put your medicine in before you reassemble the cover.
If this doesn't work, make sure you have power running to the device. Check all of your connects and try a different outlet.
Mar 01, 2011 | Computers & Internet
I have a Devilbliss Pulmo-Mate model 3650D and I plug it in and medicine does not blow out tube it only bubbles inside cup. What is wrong.
Your tubing is clogged or torn somewhere. Get a new nebulizer kit and cup and it'll be working in no time.
Jan 27, 2011 | DeVilbiss Health & Beauty
No medicine coming out of nebulizer
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
Am i hooking this nebulizer up right
First when you turn on the neb is it running and putting out air
second is the circuit or medicine cup you have new?
if not replace if yes connect tubing to spout on neb, connect other end to bottom of cup open up and put medication inside ( you can do a trial run with water just to make sure its puffing before you waste meds.
put on mputhpiece turn on should puff out like steam if not you compressor may not be putting out enough air if over 5 years old insurance should help purchace a new one with a dr rx if not call company you got it from they usually have a 5 year warranty on them.
Hope this helps
Feb 09, 2009 | DeVilbiss Pulmo Aide Compressor Nebulizer
Probasic riteneb
Jan 07, 2009 | Probasics Rite-Neb Mini Compressor...
Health & Beauty Logo
280 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
