Question about Zanussi ZSS7 / 5W Compact Refrigerator
Mains wiring diagram
I need to see where the white wiring goes at back of appliance
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Hotpoint Washing Machine Door Interlock (how to wire up)? I have removed the old door interlock and forgot to make a note of where the wires go, (wont make that mistake again) I have 3 wires White Brown...
The three wires you should have are
1-Brown-goes to L
2 Thin black to N
3 White to C..
Hotpoint never have incorporated a wiring diagram on any of their british made appliances, so previous comments made do not apply in this case.
Hope this helps.
Jan 03, 2010 | Washing Machines
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
3 wires black white ground from box from oven red black white ground what goes where
the appliance is 220 volt and the box you are describing is 110 volt. You cannot connect to this box. You need a new 220 volt circuit ran from your main panel box to the appliance with a 220 volt 3 prong outlet box like an electric dryer uses or make the connections in a box without using the plug system
Aug 17, 2009 | Frigidaire (FEB30S7D) Oven
Chef cooktop wiring
make sure that the white wires are indeed line and not neutral and you probably have the right idea but without a wiring diagram or seeing the unit I cannot confirm this just make sure you aren't hooking up line voltage to the neutral on the unit. also your service has only three wires correct? this means you are piggy backing the neutral and chassis ground (green wire on appliance) not cool on a trailer or manufactured home be careful bud
Apr 19, 2008 | Cooktops
Maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Jan 09, 2008 | Maytag MFI2568AE Side by Side French Door...
Zanussi ZSS7 / 5W Compact Refrigerator Logo
32 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
