Question about Samsung Galaxy S Iii S3 S 3 Sch-i535 - 16gb - Marble White verizon Smartphone
;; how do I remove battery
Need to know how to open phone to remove battery
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Where can i buy a phone case for this specific model #
I don't know about that particular brand phone - but many manufacturers put that info on a sticker in the battery compartment. If yours has a removable plate or door - whether for a battery or not - open it and look inside. You may need to remove the battery and a magnifying glass to read the info on the sticker.
Jul 14, 2015 | Cell Phones
How do I know which model I have? I need a manual but don't know which one to search for.
If you open the battery door and remove the battery, the make and model should be on a sticker underneath it.
Nov 25, 2011 | Lands Phones
My nokia c5 is in dead stage how can i get it back to work ? plzzz help me
First help may need to know how it got dead, water, charger, or just dead?Try this to see, remove your battery, take a small pin and adjust the open teeths in the battery terminals on your battery, sometimes when the battery contacts are too open wide, contact is not made. If that doesnt help take your usb cable, connect phone to computer and tab power button like twice, if your pc finds a new hardware your phone can be revived by flashing. take it to a repair shop for flashing.
Nov 09, 2011 | Nokia C5 Cell Phone
How to open nokia n73's parts
In order to disassemble a Nokia N73 phone first of all you need to remove the battery cover (back cover) of the phone. Then remove the battery, memory card and the SIM card.
Pry up the front cover frame by using the safe open pry tool. It is recommended to start from either of the bottom corners of the phone. First insert the safe open pry tool between the cover and the keypad of the phone to unhook the clip underneath. Do not apply too much pressure as this may damage the front cover. You can use Triangle Safe Open Pry Tool in conjunction with Safe Open Pry Tool for prying up the cover frame safely and conveniently.
Do the same to unclip the clip from the other side. Once you have undone the clips, run the tool gently along the sides of the cover to unclip all the clips. This should remove the cover without much difficulty.
Now you need to remove the display shield which holds the LCD screen in place. You need to pry the display shield up using the safe open pry tool to unlock the clips holding it in place.
Once you have the display shield removed, the next step is to remove the LCD which will now be loose enough to be lifted up. Gently lift up the LCD using the safe open pry tool but be very careful as you still have to remove a ribbon cable to be able to free the LCD. To disconnect this cable you need to gently lift it and it will pop out.
Once you have disconnected the ribbon cable, the LCD can now be lifted up and removed. Your Nokia N73 is now disassembled.
Reverse the instructions above to reassemble your phone.
Please let me know if you need more assistance.
Regards.
Nov 03, 2011 | Nokia N73 Cellular Phone
My nokia does on and off and cant open .how can i solve this problem pleas
Hi,your phone going off and on does not really mean that the phone has problem. It might be basically be from the battery.
The battery might be the problem. When a battery cell is weak and it's about getting damaged completely and it's on able to power up a phone for a long period, that means the cell of the battery is dead. It will need to be replaced with another battery.
How to open the back cover. It's easy, at the top back of the phone there is a clip holding the back cover, Push in the clip and the back cover will open, remove battery and replace.
Before you get a new battery, you could test your battery on another cell phone that uses the same battery with yours, And also test a friends battery on your cellphone too. to confirm the switching off and on, so that will can know the next step to the problem.
Hope that helped.
Thanks for using fixya...
Jan 17, 2011 | Nokia 5200 Cellular Phone
I have a motorola z3, it doesn't charge anymore and cannot communicate with my computer via usb neither as usb mass storage nor with moto pc suite. And I want to reformat it since the performance is slow....
When you plug in the cable to the phone and then to your computer, you should see the green charging Light on the upper portion of your phone, If you do not, Remove the Cable from the phone, then open the Battery compartment, remove the Battery, Examine it for leakage, or damage, if the Battery appears ok, then reseat it in the phone, secure the battery door, and replug in the usb Cable. If the Green light does not come on, try a different USB Jack on your computer. If you have Tried the Wall Charger for your phone and the green light does not come on after following the 1st step listed above, you probably need a new Battery. then you need to contact Motorola at Motorola.com click on Consumer, then Support and send them a request for help on replacing the battery. Let me know if you need further help.. :-)
Feb 21, 2010 | Motorola Mobility RAZR V3
K800i cannot open when im trying to open!!some people help me!!
hi thanks for using fixya!!
Is the problem is you cannot turn on your phone? try to remove the battery and install the battery back again, they try to turn on the power, if doesn't open, try to recharge it, if the recharging is not responding, perhaps the problem is with your battery or charger.
I suggest that you bring your phone to the service center.
If you need further assistance, let me know.
pls rate me positively! thanks!
Apr 03, 2009 | Sony Ericsson K800i Cellular Phone
How do i open a Nokia 5200
Hold the phone with the back cover facing you. On the top you will find a button that you need to press and pull the cover towards you ............. that's it
Mar 14, 2009 | Nokia 5200 Cellular Phone
I dont know how to insert my sim card
Hey,
* Open ur cell phone cover(back)
* Remove battery.
* Insert sim in a jack(symbol 'll be given aside it, along with direction of sim).
* Put ur battery n cover back..
* Swith on ur phone..
Aug 22, 2008 | Cell Phones
Samsung Galaxy S Iii S3 S 3 Sch-i535 - 16gb - Marble White verizon Smartphone Logo
124 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
