Pilot won't light
The pilot will not light. Theres gas to the valve and coming out. I cleaned the whole burner assembly and blew the pilot line out but the pilot still will not light. I've also put a new thermo coupler on. what could the problem be?
    Top Expert:
  • Heating & Co... Master
  • 43,043 Answers
There is a remote possibility that the replacement thermocouple is defective.
Posted on Nov 17, 2013
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Coleman evcon furnace
Did you clean the pilot orfice?? It has a very small opening about the size of a hair. You may have to use a needle to open the opening....Are you getting gas to the pilot orfice assembly from the Gas Valve when you set it to Pilot?? If not then check the pilot adjustment screw on top of the gas valve at the pilot tube. CW decreases flow.
Nov 17, 2013 | Heating & Cooling
Teledyne ec-400 pilot light won't light up? I can see it sparking but no ignition? Just replace the pilot burner assembly.
make sure 24 ac volts to gas valve between brown wire and ground if not check safety circuit
May 05, 2012 | Teledyne Laars Pool & Spa
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do I change the termocouple on an older Dayton furnace
Locate the gas valve,there will be three lines coming off the bottom and going into the burner compartment. The center one is the largest and is the main gas feed to burner. The one on right is usually silver and about 1/4 inch in diameter. It is the pilot feed line. The third is usually coppercolored ,this is the line for the thermocouple. You can trace thermocouple line down into burner comparment. The tip of the thermoucople usually slips into a friction fit mounted right in front of pilot burner.Slip old thermocouple out of holder and unscrew fitting from the bottom of gas valve. Install new thermocouple into pilot burner assembly,make sure thermocouple is fully seated and in direct line of pilot flame. screw fitting into bottom of gas valve. Set gas valve control to pilot,depress pilot button and light pilot. Hold pilot button down for about 2 mins.Tip of thermocouple should be cherry red. If it'snot try to reposition so thermocouple is more covered by pilot flame. Relese pilot button and if pilot stays on rotate gas valve control to on.Hope this helps you. Yhanks
Nov 20, 2010 | Dayton Gas Furnace Heater
Gas heater won't ignite
I agree. Either the pilot flame is dirty and is not making good contact to heat up the bi metal strip on the pilot assembly, or the pilot assembly is defective. 90% of the time if you clean the pilot orfice and the pilot burner it will take care of the problem
Nov 16, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
