Question about Cycling
2000 Jaguar S Type 4.0 cranks but won't start. it has spark & gas is pumping
Have you checked the timing?
Posted on Nov 17, 2013
My 2002 jaguar x type I can turn on but can't start?
Does it crank over? If it cranks, no start you need to check for gas (what is fuel pressure?) and spark (at a spark plug-to see if ignition works).
If it won't crank over, you need the start circuit looked at, possibly a bad starter but the circuit needs thoroughly tested.
Apr 01, 2017 | Jaguar Cars & Trucks
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
4.0 S TYPE CRANKS WON'T START
The first thing i would check would be the fuel pressure, the gas being sold now a days eats away at the fuel pump and makes varnish build up in pump causing the pump to go bad.
A fuel pressure gauge is needed for this test, it connects to the fuel rail and give you a reading and i would bet there is no or very very low pressure.
Jan 23, 2013 | 2000 Jaguar S-Type
2002 Ford Explorer ran out of gas put gas in and won't restart. replaced fuel pump and fuel filter still won't start. Cranks but won't start
Most Fords have a fuel reset button. When you ran out of gas you tripped the circuit. Most of the time the button will be on the passenger side by the kick panel. The exact location should be in your owners manual or your local library or auto parts store will have a copy of one for your specific vehicle.
May 08, 2012 | 2000 Cadillac Seville
2000 Jaguar xj8 turn over won't start stability control fail light on.
the stab light comes on if the battery is low because you are cranking the engine your aj26 v8 engine may have a common problem for cars up to that model/year with worn nicosil coated bores ie. low compression check the vin no. at your jag dealer you can get it started by removing the spark plugs and putting a egg cup of engine oil in to each of the cylinders the first thing to do is to check for fault codes using a obd code reader for a clue followed by a compression test
Sep 25, 2017 | 2004 Jaguar X-Type
The 1990 XJ6 has been sitting for the last 2 years and now won't start. The engine turns over fine. The dash gages don't seem to operate. I filled the gas tank with 5 gallons of premium gas. HELP!!!
I wish I could give you an instant fix, but I can't. Do you have spark? If so then its either your fuel pump or the CPS, crank position sensor. If no spark then it could be your coil.
Nov 12, 2011 | 1990 Jaguar XJ6
Jaguar xj8 2001 just completed timing chain & tensioner replacement. engine cranks won't start, what is the best trouble shooting sequence to use?
DID YOU RECONNECT IGNITION COILS AND THE VARIABLE VALVE TIMING SOLENOIDS.CHECK SPARK PLUGS IF YOU GETTING SPARK AT SPARK PLUGS.MORE LIKELY VALVE TIMING OFF.
Jul 04, 2011 | 1998 Jaguar XJ8L
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
